Home » Eclipse Projects » Oomph » Oomph installer failed installing Papyrus-RT Developer Environment(No repository found at http://download.eclipse.org/modeling/mdt/uml2/updates/5.3milestones/)
Oomph installer failed installing Papyrus-RT Developer Environment [message #1800221] Fri, 21 December 2018 08:46 Go to next message
Hello all,
I had tried to install the Papyrus-RT Developer Environment by following the Papyrus-RT/Developer/Developer Guide/DevEnv Guide (Setting up the Developer Environment) for release Oxygen.
While processing the P2 Director I got error (see below). I am not sure what the issue is. Has anyone encountered such an error before? Any assistance you provide will be of help.
Thank you
Peter
Message Log:
ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at http://download.eclipse.org/modeling/mdt/uml2/updates/5.3milestones/.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:398)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.fail(CachingRepositoryManager.java:353)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:244)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:476)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
[/color]
Re: Oomph installer failed installing Papyrus-RT Developer Environment [message #1800426 is a reply to message #1800221] Thu, 27 December 2018 14:11 Go to previous message
That's a problem in the Papyrus setup file and you should really report it to the Papyrus team, so that they know that their setup information is needed by contributors and that this information should be correct and up to date.
As Oxygen is already released I wouldn't expect UML milestone drops under 5.3. Until the Papyrus team has fixed the problem in their project setup you can work around it by (literally) copying the following snippet:
<setup:RedirectionTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    sourceURL="http://download.eclipse.org/modeling/mdt/uml2/updates/5.3milestones/"
    targetURL="http://download.eclipse.org/modeling/mdt/uml2/updates/5.3/R201706051616/"/>
... and then pasting it into your user setup, i.e., select the menu Navigate | Open Setup | User, select the "User" node in the editor and select the menu Edit | Paste.
Cheers
/Eike
Previous Topic:Unexpected location for eclipse configuration information
Next Topic:Eclipse Installer exe creation code
Current Time: Sat Jul 19 21:13:36 EDT 2025
Powered by FUDForum. Page generated in 0.24521 seconds
