Error in building shadowJar from project with multiple xtext files (Cross-reference) [message #1800368] |
Wed, 26 December 2018 00:30  |
I have a Xtext project with two xtext files having cross reference. When I tested the project as an Eclipse plugin, it worked well. Now I'm trying to create a shadowJar using gradle in order to implement my DSL in Eclipse-Che. The project generates artifacts without errors in the Eclipse editor. However, when I tried to build the shadowJar in the command prompt, I get an error saying 'XtextLinkingDiagnostic: null:1 Couldn't resolve reference to Grammar 'org.xtext.projection.CustomTerminals'.'
I will post my 2 grammar files, mwe2 file and the full error message below: -
Projection.xtext: -
grammar org.xtext.projection.Projection with org.xtext.projection.CustomTerminals
generate projection "http://www.xtext.org/projection/Projection"
Model:
elements+=Element*;
Element:
MyText | MyInt | MyDecimal | MyId | MyTime
MyText:
'Hi' name=STRING
MyInt:
'Integer:' int=INT
MyDecimal:
'Decimal:' dec=DECIMAL
MyId:
'ID:' id=ID
MyTime:
'Time:' time=TIME
CustomTerminals.xtext: -
grammar org.xtext.projection.CustomTerminals with org.eclipse.xtext.common.Terminals hidden (LINE_COMMENT, LINE_COMMENT2, /*BLOCK_COMMENT,*/ ALERT_LINE_COMMENT,
QUESTION_LINE_COMMENT, GOOD_LINE_COMMENT, REGION_COMMENT, ML_COMMENT, SL_COMMENT, WS)
generate customTerminals "http://www.xtext.org/projection/CustomTerminals"
Rule:
(rules+=Terminal)*
Terminal:
TIME | CAMELCASE_IDENTIFIER | DECIMAL
terminal ML_COMMENT : '/*' -> '*/';
terminal SL_COMMENT : '//' !('\n'|'\r')* ('\r'? '\n')?;
terminal WS : (' '|'\t'|'\r'|'\n')+;
terminal LINE_COMMENT
: ( '--' !('\r'|'\n')* )
terminal LINE_COMMENT2
: ( '//' !('!'|'?'|'='|'\r'|'\n')? !('\r'|'\n')* )
//BLOCK_COMMENT is not required since ML_COMMENT is already defined
//terminal BLOCK_COMMENT
terminal ALERT_LINE_COMMENT
: ( '//!' !('\r'|'\n')* )
terminal QUESTION_LINE_COMMENT
: ( '//?' ('\r'|'\n')* )
terminal GOOD_LINE_COMMENT
: ( '//=' !('\r'|'\n')* )
terminal REGION_COMMENT
: ( '---' ('-')+ (' ') (('A'..'Z'|'0'..'9')+ (' '))+ ('-')+ )
terminal TIME
: ( ('0'..'9')+ ':' ('0'..'9')+ )
terminal CAMELCASE_IDENTIFIER
: ('a'..'z') ('A'..'Z'|'a'..'z'|'0'..'9'|'_'|'$'|'#')*
terminal DECIMAL
: ( ('0'..'9')+ '.' ('0'..'9')+ )
terminal CHARACTER
fragment
QUOT
mwe2: -
module org.xtext.projection.GenerateProjection
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "org.xtext.projection"
rootPath = rootPath
runtimeTest = {
enabled = true
genericIde = {
enabled = true
mavenLayout = true
code = {
encoding = "windows-1252"
lineDelimiter = "\r\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
name = "org.xtext.projection.CustomTerminals"
fileExtensions = "projection"
referencedResource = "platform:/resource/org.xtext.projection/src/main/java/org/xtext/projection/Projection.xtext"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// Generates checks for @Deprecated grammar annotations, an IssueProvider and a corresponding PropertyPage
generateDeprecationValidation = true
junitSupport = {
junitVersion = "5"
parserGenerator = {
debugGrammar = true
options = {
backtrack = true
name = "org.xtext.projection.Projection"
serializer = {
validator = {
junitSupport = {
junitVersion = "5"
Error: -
> Task :org.xtext.projection:generateXtextLanguage
0 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator
5 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
82 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.xtext.projection at 'file:/D:/XtextConversion_DONOTDELETE/Completed/TEST_JAR_ProjectionForChe/org.xtext.projection.parent/org.xtext.projection/'
82 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.xtext.projection.ide at 'file:/D:/XtextConversion_DONOTDELETE/Completed/TEST_JAR_ProjectionForChe/org.xtext.projection.parent/org.xtext.projection.ide/'
89 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
366 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
371 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
388 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
388 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
415 [main] ERROR xt.generator.XtextGeneratorLanguage - Error loading 'platform:/resource/org.xtext.projection/src/main/java/org/xtext/projection/Projection.xtext':
XtextLinkingDiagnostic: null:13 STRING cannot be resolved to a rule
XtextLinkingDiagnostic: null:17 INT cannot be resolved to a rule
XtextLinkingDiagnostic: null:21 DECIMAL cannot be resolved to a rule
XtextLinkingDiagnostic: null:25 ID cannot be resolved to a rule
XtextLinkingDiagnostic: null:29 TIME cannot be resolved to a rule
743 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
812 [main] ERROR xt.generator.XtextGeneratorLanguage - [XtextLinkingDiagnostic: null:1 Couldn't resolve reference to Grammar 'org.xtext.projection.CustomTerminals'., XtextLinkingDiagnostic: null:13 STRING cannot be resolved to a rule, XtextLinkingDiagnostic: null:17 INT cannot be resolved to a rule, XtextLinkingDiagnostic: null:21 DECIMAL cannot be resolved to a rule, XtextLinkingDiagnostic: null:25 ID cannot be resolved to a rule, XtextLinkingDiagnostic: null:29 TIME cannot be resolved to a rule]
813 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow org.xtext.projection.GenerateProjection: Problem parsing 'file:/D:/XtextConversion_DONOTDELETE/Completed/TEST_JAR_ProjectionForChe/org.xtext.projection.parent/org.xtext.projection/../org.xtext.projection/src/main/java/org/xtext/projection/Projection.xtext':
java.lang.RuntimeException: Problems running workflow org.xtext.projection.GenerateProjection: Problem parsing 'file:/D:/XtextConversion_DONOTDELETE/Completed/TEST_JAR_ProjectionForChe/org.xtext.projection.parent/org.xtext.projection/../org.xtext.projection/src/main/java/org/xtext/projection/Projection.xtext':
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
Caused by: java.lang.IllegalStateException: Problem parsing 'file:/D:/XtextConversion_DONOTDELETE/Completed/TEST_JAR_ProjectionForChe/org.xtext.projection.parent/org.xtext.projection/../org.xtext.projection/src/main/java/org/xtext/projection/Projection.xtext':
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage.initialize(XtextGeneratorLanguage.java:278)
at org.eclipse.xtext.xtext.generator.StandardLanguage.initialize(StandardLanguage.java:189)
at org.eclipse.xtext.xtext.generator.XtextGenerator.initialize(XtextGenerator.java:185)
at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:139)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:21)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:65)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:197)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:29)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:18)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
... 4 more
> Task :org.xtext.projection:generateXtextLanguage FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':org.xtext.projection:generateXtextLanguage'.
> Process 'command 'C:\Program Files\Java\jdk1.8.0_181\bin\java.exe'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
* Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 5.0.
Use '--warning-mode all' to show the individual deprecation warnings.
See https://docs.gradle.org/4.10.2/userguide/command_line_interface.html#sec:command_line_warnings
BUILD FAILED in 5s
1 actionable task: 1 executed
For ease, I have uploaded the project to github: https://github.com/SharkJ/ProjectionForChe.git
Could anyone please help me resolve this error?
Regards!
[Updated on: Wed, 26 December 2018 00:34] by Moderator
FUDForum. Page generated in 0.03025 seconds
