Home » Eclipse Projects » Oomph » Unexpected location for eclipse configuration information
Unexpected location for eclipse configuration information [message #1800324] Mon, 24 December 2018 10:07 Go to next message
If I add to my eclipse product oomph setup an eclipse ini task to add the
-Dosgi.configuration.area.default=C:\Users\mario\.eclipse
I get weird message in the eclipse updater window
Bundle org.eclipse.oomph.setup.p2 1.10.0.v20180706-1242, build=3735, branch=1ac98fba42349326f02fd73178776c63324064c4
Performing Eclipse Ini -Doomph.update.url=file://cbsaecibase.omega.dce-eir.net/data/p2/download.eclipse.org/oomph/products/repository
Skipping because C:\Users\eclipse\eclipse.ini does not exist
and the workspace .metadata/.log file.
!ENTRY org.eclipse.oomph.base 4 0 2018-12-24 09:59:12.192
!MESSAGE C:\Users\eclipse\configuration\org.eclipse.oomph.setup\installation.setup (The system cannot find the path specified)
!STACK 0
java.io.FileNotFoundException: C:\Users\eclipse\configuration\org.eclipse.oomph.setup\installation.setup (The system cannot find the path specified)
	at java.io.FileOutputStream.open0(Native Method)
	at java.io.FileOutputStream.open(Unknown Source)
	at java.io.FileOutputStream.<init>(Unknown Source)
	at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl$1.<init>(FileURIHandlerImpl.java:65)
	at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createOutputStream(FileURIHandlerImpl.java:65)
	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createOutputStream(ExtensibleURIConverterImpl.java:349)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfChangedWithMemoryBuffer(ResourceImpl.java:1279)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1030)
	at org.eclipse.oomph.base.util.BaseUtil.saveEObject(BaseUtil.java:111)
	at org.eclipse.oomph.setup.ui.wizards.ProgressPage.saveLocalFiles(ProgressPage.java:1041)
	at org.eclipse.oomph.setup.ui.wizards.ProgressPage.access$22(ProgressPage.java:1018)
	at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:704)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Do you know why this is the case and how it can be prevented.
Re: Unexpected location for eclipse configuration information [message #1800343 is a reply to message #1800324] Tue, 25 December 2018 03:38 Go to previous message
It can be prevented by not doing that and of course begs the question, why are you trying to do that? The configuration used by the installation should be precisely the one that the installer has generated for that installation; what is the desired goal of redirecting it to some other arbitrary location.
Previous Topic:Problem with latest 2018-12 SimRel and Oomph
Next Topic:Oomph installer failed installing Papyrus-RT Developer Environment
Current Time: Sun Jul 20 08:49:24 EDT 2025
Powered by FUDForum. Page generated in 0.03368 seconds
