Home » Modeling » Papyrus » Model Explorer and Main Menu problem
Model Explorer and Main Menu problem [message #1799530] Sat, 08 December 2018 10:11 Go to next message
I've installed the 2018-09 Eclipse Modelling Tools and then used the following update side to install Papyrus.
Update site used:
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/2018-09
After restarting I see two strange things, visible in the figure attached.
1. The model explorer reports the following problem:
eclipse.buildId=4.9.0.I20180906-0745
java.version=1.8.0_191
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.modeling.product
org.eclipse.e4.ui.workbench
Error
Sat Dec 08 15:07:59 GMT 2018
java.lang.ClassCastException: org.eclipse.swt.layout.GridData cannot be cast to org.eclipse.swt.layout.FillData
at org.eclipse.swt.layout.FillLayout.flushCache(FillLayout.java:176)
at org.eclipse.swt.widgets.Composite.layout(Composite.java:834)
at org.eclipse.swt.widgets.Control.requestLayout(Control.java:2414)
at org.eclipse.jface.action.ToolBarManager.relayout(ToolBarManager.java:224)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:384)
at org.eclipse.sirius.ui.tools.internal.views.common.navigator.filter.FilteredCommonTree.createFilterControls(FilteredCommonTree.java:356)
at org.eclipse.sirius.ui.tools.internal.views.common.navigator.filter.FilteredCommonTree.createControl(FilteredCommonTree.java:320)
at org.eclipse.sirius.ui.tools.internal.views.common.navigator.filter.FilteredCommonTree.init(FilteredCommonTree.java:285)
at org.eclipse.sirius.ui.tools.internal.views.common.navigator.filter.FilteredCommonTree.<init>(FilteredCommonTree.java:232)
at org.eclipse.sirius.ui.tools.internal.views.modelexplorer.ModelExplorerView.createCommonViewerObject(ModelExplorerView.java:321)
at org.eclipse.ui.navigator.CommonNavigator.createCommonViewer(CommonNavigator.java:497)
at org.eclipse.ui.navigator.CommonNavigator.createPartControl(CommonNavigator.java:190)
at org.eclipse.sirius.ui.tools.internal.views.modelexplorer.ModelExplorerView.createPartControl(ModelExplorerView.java:102)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:156)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:152)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:367)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:139)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:411)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:333)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:193)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:77)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:1015)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:560)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:544)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:73)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:781)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:752)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:730)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1296)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:105)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:693)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:72)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:140)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:689)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:51)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:64)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:703)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1099)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:628)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:391)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:246)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
2. Papyrus in the the main menu doesn't look right. Does it?
A new workspace did not solve the problem.
I followed the same process with Oxygen 3 and I don't see any problem.
Am I missing some dependency?
Thanks.
[Updated on: Sat, 08 December 2018 10:13] by Moderator
Re: Model Explorer and Main Menu problem [message #1799531 is a reply to message #1799530] Sat, 08 December 2018 10:15 Go to previous messageGo to next message
I see the same problems with the nightly build.
Update site used:
http://download.eclipse.org/modeling/mdt/papyrus/updates/nightly/master
Re: Model Explorer and Main Menu problem [message #1799557 is a reply to message #1799531] Mon, 10 December 2018 03:35 Go to previous message
Hi Adriano,
Which perspective do you use? According to the StackTrace, it looks like an issue with Sirius (Or maybe an integration issue between Sirius and Papyrus). I think that Sirius and Papyrus both have a "Model Explorer" view, which mostly look the same, but are actually different implementations. Maybe you're looking at the Sirius one?
If that's indeed the issue, I'd recommend switching to the Papyrus perspective, rather than the Modeling Perspective. Papyrus ModelExplorer shouldn't even start until you open a project (e.g. from the Project Explorer or Package Explorer view)
HTH,
Camille
Previous Topic:Papyrus and Eclipse UML Generators
Next Topic:Initialize papyrus diagram
Current Time: Sun Jul 20 05:50:44 EDT 2025
Powered by FUDForum. Page generated in 0.04160 seconds
