Home » Modeling » M2T (model-to-text transformation) » Unresolved compilation error, expression was null.
Unresolved compilation error, expression was null. [message #1799371] Wed, 05 December 2018 13:35 Go to next message
I'm facing an issue with deploying Acceleo project. When I run my plugin in a new exlipse instance "Run As->Eclipse plugin" everything works fine! However, it throws the following error message when I create a Feature and UpdateSite to create a deployable version of it. The message is "Unresolved compilation error, expression was null." and the detail is shown below:
eclipse.buildId=unknown
java.version=1.8.0_181
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -data file:/C:/Users/Parsa/Desktop/capella/workspace/
org.eclipse.acceleo.engine
Warning
Wed Dec 05 13:31:24 EST 2018
org.eclipse.acceleo.engine.AcceleoEvaluationException: Unresolved compilation error, expression was null.
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1895)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitExpression(AcceleoEvaluationVisitor.java:1049)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoQueryInvocation(AcceleoEvaluationVisitor.java:880)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1951)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.java:600)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1912)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.java:922)
	at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1906)
	at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(QueryImpl.java:146)
	at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:56)
	at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvaluate(AcceleoEngine.java:365)
	at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate(AcceleoEngine.java:142)
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerateTemplate(AcceleoService.java:984)
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:652)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:209)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:172)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:159)
	at org.polarsys.capella.aql.transformation.main.Generate.doGenerate(Generate.java:217)
	at org.polarsys.capella.aql.transformation.ui.common.GenerateAll.doGenerate(GenerateAll.java:88)
	at org.polarsys.capella.aql.transformation.ui.popupMenus.AcceleoGenerateTransformtoXSDAction$1.run(AcceleoGenerateTransformtoXSDAction.java:77)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Please advise.
Parsa
Re: Unresolved compilation error, expression was null. [message #1799377 is a reply to message #1799371] Wed, 05 December 2018 14:52 Go to previous messageGo to next message
"works fine" is not always the same as "is fine".
I suspect that your deployment detects some latent problem.
Ed Willink
Re: Unresolved compilation error, expression was null. [message #1799379 is a reply to message #1799377] Wed, 05 December 2018 15:07 Go to previous messageGo to next message
Hi Ed,
Do you know any types of latent problem that can cause this? My original Acceleo version is 3.7.1 but the target eclipse has Acceleo version of 3.7.6. Can it be a problem ? My attempts to synchronise the two versions have failed so far!
Best Regards,
Parsa
Re: Unresolved compilation error, expression was null. [message #1799382 is a reply to message #1799379] Wed, 05 December 2018 15:49 Go to previous message
Yes, read my Bugzillas. But I stopped using Acceleo at about 3.4. I don't care to enumerate all the ways you can make a mistake in the total absence of any repro.
Ed Willink
Previous Topic:Strange behaviour on generating text - Indentations do not match
Next Topic:Generate Output files in a different folder than the project
Current Time: Sat Jul 19 13:53:20 EDT 2025
Powered by FUDForum. Page generated in 0.04372 seconds
