Home » Modeling » EMF » Problem with load
Problem with load [message #1798685] Thu, 22 November 2018 11:55 Go to next message
Hi there,
When I load the resource with resource.load(null) it does not clear the previous content. What shall I do?
In the below code, the `Test` method is called several times. First, I load the resource and at the end I delete the resource in order the previous content is cleared for next method call but it still has the previous content.
public ArrayList<EObject> Test(Resource r) {
		try {
			r.load(null);
		} catch (IOException e) {
			e.printStackTrace();
		//do something and store results in expressions variable
		try {
			r.delete(null);
	    return expressions;
[Updated on: Thu, 22 November 2018 11:56] by Moderator
Re: Problem with load [message #1798704 is a reply to message #1798685] Thu, 22 November 2018 23:59 Go to previous messageGo to next message
The debugger in your friend. If you'd stepped through the code with your friend, you'd find that all the load methods are guarded like this:
  public void load(Map<?, ?> options) throws IOException
    if (!isLoaded)
Then if you looked through the code of ResourceImpl, you'd see that this isLoaded field is changed only by setLoaded, which is protected, so you can't call it directly. Looking further at the Call Hierarchy of that method, you'd notice that unload() sets it to false. Then you would have answered the question yourself, i.e., you must unload the resource before it can be loaded again.
Re: Problem with load [message #1800560 is a reply to message #1798704] Wed, 02 January 2019 08:07 Go to previous messageGo to next message
Hi there,
I have used unload method but it still doesn't work. It only works when I delete the model and save new model with the new name.
		try {
			r.load(null);
		r.unload();
	    return expressions;
Best Regards,
Banafsheh
Re: Problem with load [message #1800566 is a reply to message #1800560] Wed, 02 January 2019 09:49 Go to previous message
There isn't a question mark, so there isn't a question? Did you intend at some point to call unload first and then call load afterwards? Did you look at any of what's going on using the debugger?
Previous Topic:[CDO] Auto-Commit in CDO
Next Topic:[CDO] Caching and explicit garbage collection
Current Time: Sun Jul 20 14:06:46 EDT 2025
Powered by FUDForum. Page generated in 0.03334 seconds
