Home » Eclipse Projects » e(fx)clipse » dragging is slow under e(fx)clipse
dragging is slow under e(fx)clipse [message #1795262] Wed, 19 September 2018 07:35 Go to next message
I have the same program which can drag selected visual elements (JavaFX based). I launched the program under two conditions: JavaFX application and Eclipse application. My observation turned out that dragging is slower in eclipse application than in JavaFX application (not so fluent ).
My questions: how are visuals rendered under eclipse application? Is it able to adjust the rendering frequency? Thank you.
Best Regards
Shenwei Zheng
Re: dragging is slow under e(fx)clipse [message #1797649 is a reply to message #1795262] Sat, 03 November 2018 18:02 Go to previous messageGo to next message
Please qualify Eclipse - do embed it into SWT?!
Re: dragging is slow under e(fx)clipse [message #1797802 is a reply to message #1797649] Tue, 06 November 2018 09:43 Go to previous messageGo to next message
Hi Thomas,
yes, it is embedded in SWT.
Additional I have prepared a sample project in attachment. The application can be started either with SampleApplication.java or can be launched with e4.performance.sample.product.
With the key control and mouse dragging, the complete view can be dragged. And I noticed dragging view under E4 application is slower and not fluent. Besides, I tested dargging with a Hi-DPI monitor and the dragging is slower.
Please have a try with my sample application. I am not sure if my conclusion is correct or you might have an explaination, thank you.
Bests
Shenwei Zheng
[Updated on: Tue, 06 November 2018 09:47] by Moderator
Re: dragging is slow under e(fx)clipse [message #1797819 is a reply to message #1797802] Tue, 06 November 2018 18:52 Go to previous message
Well if you integrate fx into swt the slow down is more or less expected - you off load from the GPU to main memory, produce an image and paint that (uploading the very same pixels) to the GPU
Previous Topic:MVN OSGI-Launcher cannot start
Next Topic:how to enable the ciphers suite which disabled by jetty9.4.12 (default setting)
Current Time: Sun Jul 20 17:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.04100 seconds
