printing problem [message #179184] |
Mon, 25 April 2005 17:06  |
My figures have Labels with image icons and text. My problem is that only
the text is getting printed, but not the icons. I searched the newsgroup
archive and found many posts about icons printed as either black boxes
(tranparency issue) or as black dots and that these bugs have been fixed.
But, my icons are still not being printed.
I'm using GEF 3.1M5. I registered a new default PrintAction in my editor
and added ActionFactory.PRINT.getId() as a GlobalActionKey. Should i be
doing something else? Calling print in some other way?
thanks
Sapna
Re: printing problem [message #180402 is a reply to message #180381] |
Wed, 04 May 2005 18:27   |
Sapna, not being able to reopen does not prevent you from posting to that
bug report. You should CC yourself to it, describe your problem and provide
the icon and the SWT folks will reopen the bug if your problem's genuine.
However, if I were you, I'd check your setup again. I just tried their
snippet with your icon and 0502 build, and it worked just fine.
"Sapna George" <sgeorge@vt.edu> wrote in message
news:d5bc5q$8qa$1@news.eclipse.org...
> The webmaster gave me this answer:
> Hello Sapna,
> You need to address the following email to the committers of the
> project, they are the only ones that can reopen this bug.
> Thanks
> Regards
> Sujay
> I'm attaching the gif file to this post. Can you reopen the bug?
> Sapna
> "Pratik Shah" <ppshah@us.ibm.com> wrote in message
> news:d58m1i$20r$1@news.eclipse.org...
> > Could be. Make sure you're logged in and if you still don't see the
> option,
> > try CCing yourself on that bug report. Ask the eclipse webmaster if the
> > problem persists.
> > news:02817f2eeed1f3b31586a646c078bf62$1@www.eclipse.org...
> > > For this bug (28766), i see only 1 option: Leave as RESOVED FIXED. No
> > > reopen option like in some other bugs i have seen. Is my account
> 'special'
> > > (low previleges, maybe)?
Re: printing problem [message #180509 is a reply to message #180469] |
Fri, 06 May 2005 09:16  |
It could be specific to the printer driver that you have.
(go hoos!;-)
news:b62a53a6f5d7e32fef0e71bbe60ef721$1@www.eclipse.org...
> thanks for your response. I'll try to send the bug report.
> But, I'm clueless as to what 'setup' i should check as far as the image is
> concerned. If it's working fine with you, obviously i'm doing something
> wrong!
> sapna
FUDForum. Page generated in 0.06400 seconds
