Home » Eclipse Projects » Sirius » list creation(How to create a list of integer in sirius)
list creation [message #1797260] Mon, 29 October 2018 06:29 Go to next message
After a lot of tests, I still can not design a variable of the integer list type. I understand that i have to use the widget list but I do not know how to use it. Do you have an example of list creation, please?
Romain Launay
Re: list creation [message #1797380 is a reply to message #1797260] Tue, 30 October 2018 09:08 Go to previous message
You can define a Text[1] widget. In the dialog it will provide a text field to fill in the value of your integer. In the model operations, under the begin element of your screenshot, you can access to the value filled in the text field using the variable "newValue".
Steve
[1]https://www.eclipse.org/sirius/doc/specifier/properties/Properties_View_Description.html#text
Previous Topic:Default value
Next Topic:[Sirius&ELK]Edge label overlap
Current Time: Sun Jul 20 12:53:49 EDT 2025
Powered by FUDForum. Page generated in 0.03517 seconds
