Home » Newcomers » Newcomers » Installing Oxygen on my computer(Want previous version)
Installing Oxygen on my computer [message #1796923] Mon, 22 October 2018 06:47 Go to next message
you have changed the Eclipse Installer recently. Now i do not know how to install Eclipse Oxygen anymore. Previously Eclipse had an option (in the Eclipse Installler) where we could choose version (for instance Oxygen). There are problems with the newer versions of Eclipse - related to our application. We cannot use them yet. I have not found any sources on how to do this properly. Can somebody help me (urgent)?
I only need to install Oxygen (64 bits on windows).
After a time-consuming search on the Eclipse pages i finally found Oxygen directories an files (zip) but now instruction on how to launch/install/start it.
Any help is welcome.
Best wishes
anders
Re: Installing Oxygen on my computer [message #1796949 is a reply to message #1796923] Mon, 22 October 2018 19:01 Go to previous messageGo to next message
The Eclipse Installer from this page provides the options for which version to install:
https://wiki.eclipse.org/Eclipse_Installer
The installer you download from the download page is a "crippled" version that will only install the latest version. If you keep the installer somewhere permanently and/or update up, you'll always have to option to install any available version of Eclipse without downloading the installer itself again.
Re: Installing Oxygen on my computer [message #1797203 is a reply to message #1796923] Sat, 27 October 2018 22:31 Go to previous messageGo to next message
Anders,
could you post the link to OLDER Oxygen downloads ?
I have recently lost my Oxygen March 2018 and would like to get it back.
Actually I would prefer even older versions - March 2018 seems to be last of the Oxygen and not the best.
Re: Installing Oxygen on my computer [message #1797212 is a reply to message #1797203] Sun, 28 October 2018 10:36 Go to previous messageGo to next message
This page has links to the different releases of Eclipse.
http://www.eclipse.org/downloads/packages/release
Re: Installing Oxygen on my computer [message #1797213 is a reply to message #1797212] Sun, 28 October 2018 11:42 Go to previous messageGo to next message
David, thanks.
Your reply is very helpful.
Would you know where I can get CORRECT version of Java too?
I have unknown version of Oxygen I tried to install and got ton of "...you need Java 1.8..."
I am not sure how I managed to make Oxygen April 2018 to "work" but I know Match 2018 was much more "user friendly / predictable ".
Actually - as a follow -up question , if do not mind -
HOW do I tell my current version of Oxygen WHICH Java version it is using?
I know I can query for Java proper, but have no idea what Oxygen is actually using.
It seems very odd that Eclipse , Oxygen in particular , needs such "ancient" version of Java.
Addendum
Successfully installed and running Oxygen #3 (March 2018)
No longer have to close / open project to update dirty source files.
The key is - "installer" does not install older versions of anything!
Now busy cleaning up the mess of various "versions" of Eclipse.
Lesson learn - if it ain't broke DO NOT UPDATE !
Hopefully case closed , but NOT SOLVED!
SORRY FOR THE HIJACK!
[Updated on: Sun, 28 October 2018 12:57] by Moderator
Re: Installing Oxygen on my computer [message #1797226 is a reply to message #1797213] Sun, 28 October 2018 15:11 Go to previous messageGo to next message
Have you tried the expert mode of the installer?
Just click the menu box (horizontal stripes on top right) and select Expert Mode.
Re: Installing Oxygen on my computer [message #1801429 is a reply to message #1797213] Fri, 18 January 2019 17:12 Go to previous message
Anne Creek wrote on Sun, 28 October 2018 11:42
For that first part, in the About dialog hit the Installation Details button. The Configuration tab of that dialog then contains the Java system properties for what's being used to run Eclipse (and a lot more). You'll need to scroll down a page or two.
For the second, it's tied to the changes in Oracle's support policies: https://www.oracle.com/technetwork/java/java-se-support-roadmap.html . 8 only seems ancient because 9 and 10 were only current for 6 months each (and are already out of support in favor of 11, which will be around longer).
Previous Topic:Unable to open Eclipse oxygen - window 10
Next Topic:failed to install eclipse
Current Time: Sun Jul 20 18:32:04 EDT 2025
Powered by FUDForum. Page generated in 0.09368 seconds
