Home » Modeling » TMF (Xtext) » Need help to implement an ambiguous grammar (ACSL grammar)(how to fix ambigus grammar)
Need help to implement an ambiguous grammar (ACSL grammar) [message #1794841] Fri, 07 September 2018 10:03 Go to next message
Hello everybody,
I post a message here, because I'm not able to find how to manage trouble with ambiguous grammar.
I'm implementing a part of the ACSL Grammar (see https://frama-c.com/download/acsl_1.3.pdf). Basically it allows to write annotations in C code.
This grammar provides many rules. My problem comes from Term and Predicat (Pred) definitions which use common symbols. Here an abtract of this grammar:
Grammar of Terms:
literal::= \true | \false | integer | real | string | char
bin-op::= + | - | * | / | % | << | >> | == | != | <= | >= | > | < | && | || | ^^:
term::= literal |
\result |
term bin-op term
| and others possibilities
Grammar of Pred:
rel-op::= == | != | <= | >= | > | < (Yes, these symbols are also available in bin-op)
pred::= \true | \false |
term (rel-op term)+ |
pred && pred | (&& is also available in bin-op)
pred || pred | (|| is also available in bin-op)
and others possibilities.
With the grammar plugins in attachement, the ambiguous bin-on symbols are commented, so the next sentence is valid:
requires \result >= 12 && \result <= 15; (rule RequiresClause)
It is the rule RequiresClause ('requires' pred=PredExpression) where the PredExpression is a PredConjuction (pred1 && pred2) with pred1="\result >= 12" and pred2="\result <= 15".
pred1 and pred2 are identified as the rule Pred_TermComparison (a comparison of 2 Terms with a RelOp (== | != | <= | >= | > | <).
This usecase works fine.
Now, if I uncomment one of the ambiguous bin-op symbol (== | != | <= | >= | && | ...), my sentence is not yet recognized as valid by the framework.
By example, uncommenting <= in the bin-op rule, I assume, the framework interprete the sentence as:
\result >= 12 is now seen as a term
\result >= 15 as a pred (as previously)
so we have as now a conjunction between a term and a pred and it is not valid.
Please, could you indicate me a way to fix my troubles (parameters to add in the mw2e file, generated code to override or whatever).
you will find in attachement:
- the xtext plugins for this grammar
- some snapshot of the ACSL grammar
Here my mwe2 file and my grammar (also in the attached plugins of course):
The mwe2 file
module com.cea.xtext.demo.GenerateAcslDemo
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
	bean = org.eclipse.emf.mwe.utils.StandaloneSetup {
	//		platformUri = "${rootPath}"
		scanClassPath = true
		//load EMF ECORE
		uriMap = {
			from = "platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore"
			to = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore"
		uriMap = {
			from = "platform:/plugin/org.eclipse.emf.codegen.ecore/model/GenModel.genmodel"
			to = "platform:/resource/org.eclipse.emf.codegen.ecore/model/GenModel.genmodel"
		uriMap = {
			from = "platform:/plugin/org.eclipse.emf.ecore/model/Ecore.genmodel"
			to = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
		registerGeneratedEPackage = "org.eclipse.emf.ecore.EcorePackage"
		registerGenModelFile = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
		registerGeneratedEPackage = "org.eclipse.emf.codegen.ecore.genmodel.GenModelPackage"
		registerGenModelFile = "platform:/resource/org.eclipse.emf.codegen.ecore/model/GenModel.genmodel"//load UML
////Types
		uriMap = {
			from = "platform:/plugin/org.eclipse.uml2.codegen.ecore/model/GenModel.ecore"
			to = "platform:/resource/org.eclipse.uml2.codegen.ecore/model/GenModel.ecore"
		uriMap = {
			from = "platform:/plugin/org.eclipse.uml2.codegen.ecore/model/GenModel.genmodel"
			to = "platform:/resource/org.eclipse.uml2.codegen.ecore/model/GenModel.genmodel"
		uriMap = {
			from = "platform:/plugin/org.eclipse.uml2.types/model/Types.ecore"
			to = "platform:/resource/org.eclipse.uml2.types/model/Types.ecore"
		uriMap = {
			from = "platform:/plugin/org.eclipse.uml2.types/model/Types.genmodel"
			to = "platform:/resource/org.eclipse.uml2.types/model/Types.genmodel"
		uriMap = {
			from = "platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore"
			to = "platform:/resource/org.eclipse.uml2.uml/model/UML.ecore"
		uriMap = {
			from = "platform:/plugin/org.eclipse.uml2.uml/model/UML.genmodel"
			to = "platform:/resource/org.eclipse.uml2.uml/model/UML.genmodel"
		registerGeneratedEPackage = "org.eclipse.uml2.codegen.ecore.genmodel.GenModelPackage"
		registerGenModelFile = "platform:/resource/org.eclipse.uml2.codegen.ecore/model/GenModel.genmodel"
		registerGeneratedEPackage = "org.eclipse.uml2.uml.UMLPackage"
		registerGenModelFile = "platform:/resource/org.eclipse.uml2.uml/model/UML.genmodel"
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "com.cea.xtext.demo"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				lineDelimiter = "\n"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "com.cea.xtext.demo.AcslDemo"
			fileExtensions = "acslDemo"
			fragment = ecore2xtext.Ecore2XtextValueConverterServiceFragment2 auto-inject {}
			serializer = {
				generateStub = false
			validator = {
			// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
			parserGenerator = parser.antlr.XtextAntlrGeneratorFragment2 auto-inject {
				debugGrammar = true
				combinedGrammar = true
				options = {
					backtrack = true
			fragment = idea.parser.antlr.XtextAntlrIDEAGeneratorFragment auto-inject {
				options = {
					backtrack = true
The grammar
grammar com.cea.xtext.demo.AcslDemo with org.eclipse.xtext.common.Terminals
generate acslDemo "http://www.cea.com/xtext/demo/AcslDemo"
import "http://www.eclipse.org/uml2/5.0.0/UML" as uml
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
 * the input rule to edit an opaque behavior
OpaqueBehaviorRule:
	contract=FunctionContract;
 * defined in figure 2.5 page 29
FunctionContract:
	{FunctionContract} (requiresClause+=RequiresClause)*
 * defined in figure 2.5, page 29
RequiresClause:
	'requires' pred=PredExpression ';';
//TERMS
TermExpression:
	TermBinOpExpression;
TermBinOpExpression returns TermExpression:
		TermArrayAccess ({TermBinOpExpression.left=current} op=BinOp right=TermArrayAccess)*
TermArrayAccess returns TermExpression:
	TermPrimary ({TermArrayAccess.left=current} '[' right=TermPrimary ']')*;
TermPrimary returns TermExpression:
	{TermParenthesis} '(' termInParenthesis=TermExpression ')' | Term_UnaryOp | TermNot | {TermOld} '\\old' '('
	termInOld=TermExpression ')' | TermAtomic
TermNot returns TermExpression:
	'!' exp=TermPrimary;
TermAtomic returns TermExpression:
	{TermLiteral} lit=Literal | Term_Result |  Term_PolyId;
Term_PolyId returns TermExpression:
	{Term_PolyId} ident=Ident;
Ident:
	id=ID;
 * We adapt the pred description defined in Figure 2.2
 * to avoid left recursive grammar and others troubles
//Pred:
//	expression=PredExpression
////	pred=Pred_Basic secondMember+=(Pred_RightMember)*
//PRED-PRED-PRED-PRED-PRED-PRED-PRED-PRED-PRED-PRED-PRED-PRED-PRED-
PredExpression:
	PredImplication;
PredImplication returns PredExpression:
	PredEquivalence ({PredImplication.left=current} '==>' right=PredEquivalence)*;
PredEquivalence returns PredExpression:
	PredOrExpression ({PredEquivalence.left=current} '<==>' right=PredOrExpression)*;
PredOrExpression returns PredExpression:
	PredAndExpression ({PredOrExpression.left=current} '||' right=PredAndExpression)*;
PredAndExpression returns PredExpression:
	PredXorExpression ({PredAndExpression.left=current} '&&' right=PredXorExpression)*;
PredXorExpression returns PredExpression:
	PredPlusOrMinus ({PredXorExpression.left=current} '^^' right=PredPlusOrMinus)*;
PredPlusOrMinus returns PredExpression:
	PredMulOrDiv (({PredPlus.left=current} '+' | {PredMinus.left=current} "-") right=PredMulOrDiv)*;
PredMulOrDiv returns PredExpression:
	PredPrimary ({PredMulOrDiv.left=current} op=('*' | '/') right=PredPrimary)*;
PredPrimary returns PredExpression:
	Pred_TermComparison |{PredParenthesis} '(' pred=PredExpression ')' | {PredNot} '!' exp=PredPrimary  | {PredOld} '\\old' '('
	pred=PredExpression ')' | PredAtomic;
////defined in Figure 2.2
enum RelOp:
	EQUALS="=="
	| NOT_EQUALS="!="
	| SUPERIOR_STRICT=">"
	| SUPERIOR_OR_EQUALS=">="
	| INFERIOR_STRICT="<"
	| INFERIOR_OR_EQUALS="<=";
Pred_TermComparison returns PredExpression:
	{Pred_TermComparison} left=TermExpression right+=Pred_TermComparisonRight+;
Pred_TermComparisonRight:
	op=RelOp right=TermExpression;
PredAtomic returns PredExpression:
	Pred_True
	| Pred_False;
Pred_True returns PredExpression:
	{Pred_True} "\\true";
Pred_False returns PredExpression:
	{Pred_False} "\\false";
	//END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED-END_PRED
//END_TERMS
Literal:
	LiteralBoolean
	| LiteralInt
	| LiteralReal
	| LiteralString
	| LiteralChar;
LiteralBoolean:
	value=("\\true" | "\\false");
LiteralInt:
	i=INT;
LiteralString:
	s=STRING;
LiteralReal:
	r=REAL;
LiteralChar:
	c=CHAR;
terminal REAL:
	INT '.' INT;
terminal CHAR:
	('a'..'z' | 'A'..'Z');// | '_' | '0'..'9');
//terminal BOOLEAN:
//	('\\true' | '\\false');
// * binary operators
// * figure 2.1 page 16 in document acsl_1.13.pdf
enum BinOp:
	PLUS="+"
	| MINUS="-"
	| STAR = "/*"
	| SLASH="/"
	| PERCENT = "%"
	| LEFT_SHIFT = "<<"
	| RIGHT_SHIFT = ">>"
//	| DOUBLE_EQUALS = "=="
//	| NOT_EQUALS = "!="
//	| TODO1 = "<=" //TODO
//	| TODO2 = ">="//TODO
//	| TODO3 = ">"//TODO
//	| TODO4 = "<"//TODO
//	| BOOLEAN_AND_OPERATION = "&&"
//	| BOOLEAN_OR_OPERATION = "||"
//	| BOOLEAN_XOR_OPERATION= "^^"
	| BITWISE_AND_OPERATION = "&"
	| BITWISE_OR_OPERATION = "|"
	| BITWISE_XOR_OPERATION = "^"
// * unary operators
enum UnaryOp:
	UNARY_PLUS="+"
	| UNARY_MINUS="-"
	| BOOLEAN_NEGATION="!"
	| BITWISE_COMPLEMENTATION="~"
	| POINTER_DEFERENCING="*"
	| ADRESS_OF_OPERATOR="&";
Term_UnaryOp returns TermExpression:
	unaryOperator=UnaryOp referencedTermInUnaryOpTerm=TermExpression;
Term_Result:
	{Term_Result} '\\result';
terminal ID : ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ;// | ('\'' -> '\'')  ;
Vincent LORENZO
Re: Need help to implement an ambiguous grammar (ACSL grammar) [message #1794844 is a reply to message #1794841] Fri, 07 September 2018 10:43 Go to previous messageGo to next message
The C grammar has the notorious dangling else ambiguity amongst others. It appears that your ACSL exposition introduces further gratuitous ambiguities.
I understand that Xtext now has syntactic predicates so you can just make the ambiguity go away, but only until you get complaints from your users that your intuitive resolution conflicts with theirs.
I prefer to solve ambiguities by design and so I use LALR tooling where you have to fight with the delights of reduce-reduce and shift-reduce conflicts until your grammar is unambiguous.
To facilitate using the LPG LALR parser with Xtext, I have developed the experimental GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.xtext2lpg plugin - only available from the OCL GIT.
You may find that the yaccable C++ grammar that I developed during my PhD helpful: http://www.cs.technion.ac.il/users/yechiel/c++-faq/yaccable-grammar.html
Ed Willink
Re: Need help to implement an ambiguous grammar (ACSL grammar) [message #1794856 is a reply to message #1794844] Sat, 08 September 2018 03:14 Go to previous messageGo to next message
you have multiple problems
(1) unusal pattern for unary expressions. ususal pattern is
Term_UnaryOp returns TermExpression: {Term_UnaryOp}op=UnaryOp p=TermPrimary | TermPrimary;
(2) duplicate not (its in unary and a separate one
(3) you have an actually left cycle between the primaries
i recommend you to generate a debug grammar
parserGenerator = {
debugGrammar = true
and use antlrworks to inspect
Re: Need help to implement an ambiguous grammar (ACSL grammar) [message #1794886 is a reply to message #1794856] Mon, 10 September 2018 06:35 Go to previous message
See also https://blogs.itemis.com/en/debugging-xtext-grammars-what-to-do-when-your-language-is-ambiguous
Previous Topic:Plain Language parser in xtext xbase
Next Topic:XText importing a specific file extension
Current Time: Sun Jul 20 08:33:54 EDT 2025
Powered by FUDForum. Page generated in 0.04776 seconds
