Home » Newcomers » Newcomers » Eclipse hangs for 10 to 20 seconds on storing, browsing old projects
Eclipse hangs for 10 to 20 seconds on storing, browsing old projects [message #1794633] Tue, 04 September 2018 04:57 Go to next message
I'am using Photon Release (4.8.0) in a workspace with serveral "old projects" (projects created in former Eclipse versions). Meanwhile new created projects are working smoothly it is impossible to wok on old projects, during nearly every action, like storing, opening, or working in the project tree, Eclipse hangs for 10 to 20 seconds, without any information.
I already closed and "deleted" the projects and reimported it, I cleaned up the projects, disabled "Build automatically", nothing has helped.
I am using eclipse with java version "1.8.0_31" on a MacOS High Sierra. The projects are java servlet web projects using vaadin and ivy.
I hope someone can help me, because currently you can´t work on these projects.
Florian
Re: Eclipse hangs for 10 to 20 seconds on storing, browsing old projects [message #1794639 is a reply to message #1794633] Tue, 04 September 2018 07:06 Go to previous message
I don't know the solution to the problem, but working for a customer with a huge workspace full of many Java projects I also saw many long UI freezes. You could try to enable General -> Error Reporting because this this captures stack traces during freezes, which might give you a clue (or to report a problem). Or you could use jvisualvm (it's part of the Java SDK) to see what all the threads are doing. In my case, the workspace had a huge number of warnings and I could see that updating the decorations for warnings was causing the freezes, so I deleted all the warning from the problems view (I only actually work on a few of the projects) eliminated this cost.
Previous Topic:In Jboss Tools of Openshift, Can we host Android Application?
Next Topic:Save button and save all don't function
Current Time: Sat Jul 19 11:27:32 EDT 2025
Powered by FUDForum. Page generated in 0.28446 seconds
