Error on first generation regarding superType [message #1792763] |
Mon, 23 July 2018 11:43  |
With the DSL I create a number of subclasses instead of a single class for each needed class. In the example I only created one subclass but in the real usecase for DSL there could be too many to create an own class for each one. (thats the reason why I attempt to create subclasses)
The error only appears on the first code generation. Instead of the expected
"class A extends B"
Xtext generates
"class A implements B"
After the second code generation it works as expected.
The issue appears with the "IdWithKeyElementInferrerExtension" (part of the inferrer).
With the following method I could fix the problem with the generated class(container for the subclasses) itself:
void IJvmDeclaredTypeAcceptor.accept(JvmGenericType type, Procedure1<? super JvmGenericType> lateInitialization)
acceptor.accept(
element.toClass(element.name) [
packageName = element.packageName
[superTypes += BaseClass.typeRef
But I have no clue how or if it is possible to set the inheritance reference for the subclasses in the "lateInitialization".
Example project is in the attachments.
FUDForum. Page generated in 0.06280 seconds
