Home » Eclipse Projects » Paho » Public multiples topic to Mosquitto server using Paho C library(Public multiples topic to Mosquitto server using Paho C library)
Public multiples topic to Mosquitto server using Paho C library [message #1771291] Wed, 23 August 2017 13:34 Go to next message
I'm trying g to public multiples topic to Mosquitto server using Paho C library and the first to topic is published OK, but when I tried the second it give me "Connect failed, rc -11".
Note: I'm using "MQTTAsync_publish.c" example as template. I have to connect and disconnect in each publication, required
Waiting for publication of test
on topic MQTT Examples1 for client with ClientID: ExampleClientPub
Successful connection
Message with token value 1 delivery confirmed
Successful disconnection
Second Topic
Waiting for publication of test2
on topic MQTT Examples2 for client with ClientID: ExampleClientPub
[Updated on: Wed, 23 August 2017 13:47] by Moderator
Re: Public multiples topic to Mosquitto server using Paho C library [message #1793927 is a reply to message #1771291] Mon, 20 August 2018 11:03 Go to previous messageGo to next message
Hi ,
I have the same (or a similiar problem).
I am sending very fast publish messages to the broker. 2 messages are accepted by the paho MQTT C lient (async), when I post the third message I get the the same error (-11, MQTTASYNC_OPERATION_INCOMPLETE).
Is there a limitation, how much messages the paho client can accept simultaneously?
Or is there a specific behaviour I have to observe?
Re: Public multiples topic to Mosquitto server using Paho C library [message #1795291 is a reply to message #1793927] Thu, 20 September 2018 00:28 Go to previous message
There should be no problem in subscribing two or more times quickly. You should check that the MQTT broker doesn't show any errors. If it doesn't, then taking a trace of the Paho client library (see the readme for details) should help work out what is happening.
Note also that it is possible to subscribe to more than 1 topic in the same request.
[Updated on: Thu, 20 September 2018 00:31] by Moderator
Previous Topic:C Paho Api Threading Issue
Next Topic:Wants to create multiple connections without too many threads
Current Time: Sat Jul 19 19:21:31 EDT 2025
Powered by FUDForum. Page generated in 0.09116 seconds
