Home » Eclipse Projects » GEF » Add LayoutAlgorithm in MinMap example
Add LayoutAlgorithm in MinMap example [message #1793713] Tue, 14 August 2018 09:28 Go to next message
I've been trying for a while but couldn't do it.
Where, if possible, can I add a LayoutAlgorithm to the MinMap example? (https://www.itemis.com/en/gef/tutorials/part-2-gef-mvc/)
For example the SpringLayoutAlgorithm().
Re: Add LayoutAlgorithm in MinMap example [message #1793772 is a reply to message #1793713] Wed, 15 August 2018 09:26 Go to previous messageGo to next message
Hi Joao,
the mind map tutorial should contain a chapter about layout integration IIRC.
I will have a closer look later today. Maybe I can give a minimal example.
Matthias
[Updated on: Wed, 15 August 2018 09:27] by Moderator
Re: Add LayoutAlgorithm in MinMap example [message #1794027 is a reply to message #1793772] Wed, 22 August 2018 11:46 Go to previous messageGo to next message
I was trying to implement this using the "GraphPart()" and adding it to the module Bindings like this:
		adapterMapBinder.addBinding(AdapterKey.defaultRole())
		.to(LayoutContext.class);
		.to(GraphLayoutBehavior.class);
but I noticed that the MindMap example does not have org.eclipse.gef.graph.Nodes or Edges.
I've been trying for hours but still didn't manage to populate a Graph so that I can:
1-Set a layout Algorithm to that Graph
2-Use ELK on the Nodes and Edges of my Part
What am I missing?
Re: Add LayoutAlgorithm in MinMap example [message #1803077 is a reply to message #1794027] Thu, 21 February 2019 16:24 Go to previous messageGo to next message
Hi Joao,
sorry, for not coming back to this earlier.
The LayoutAlgorithm can be set as an attribute on the Graph object. In order to integrate ELK with current Zest defaults, you would need to implement an ILayoutAlgorithm that transforms the Graph, invokes ELK, and applies the results back. Using default LayoutBehaviors requires to read and write LayoutProperties[1].
However, you are not bound to conform to this mechanism. Maybe it is easier to create a LayoutPolicy that does not force a layout mechanism on to you but a transaction mechanism that enables you to undo/redo a layout. The main difference would be that a LayoutPolicy needs to be invoked explicitly while a LayoutBehavior will react on its own. The latter is good enough for most cases, but when seeking more control, replacing it with a passive component (Policy) is a viable approach.
[1] https://github.com/eclipse/gef/blob/6920fe104da1ae4b6b841e31850e7dc89d1ede57/org.eclipse.gef.layout/src/org/eclipse/gef/layout/LayoutProperties.java#L27
Matthias
Re: Add LayoutAlgorithm in MinMap example [message #1803382 is a reply to message #1803077] Wed, 27 February 2019 10:44 Go to previous messageGo to next message
Dear Matthias,
I just want to apply different layout algorithms to my entire map (several Nodes + Connections). Is there any easy way of doing it and/or any example of toggling between different layout algorithms? Namely, how would you apply different layout algorithms to the MinMap example?
João
[Updated on: Wed, 27 February 2019 11:31] by Moderator
Re: Add LayoutAlgorithm in MinMap example [message #1833432 is a reply to message #1803382] Tue, 13 October 2020 01:28 Go to previous message
Hello João
The GEF Mindmap Tutorial contains an entire chapter about layouting:
Part VI Automatic layouting
Step 17: Automatic layouting via GEF layout
Step 18: Automatic layouting via Graphviz DOT
Step 19: Automatic layouting via the Eclipse Layout Kernel
See also https://blogs.itemis.com/en/getting-started-with-eclipse-gef-the-mindmap-tutorial
Hope that helps,
Tamás
Previous Topic:Snap To Object - GEF5
Next Topic:Advice for reordering tree items using AbstractTreeEditPart & policies??
Current Time: Sun Jul 20 12:13:51 EDT 2025
Powered by FUDForum. Page generated in 0.07072 seconds
