Home » Eclipse Projects » EclipseLink » EclipseLink-Moxy Unable to load custom DomHandler in OSGI environment(EclipseLink-Moxy Unable to load custom DomHandler class while instantiating JAXB context)
EclipseLink-Moxy Unable to load custom DomHandler in OSGI environment [message #1793668] Mon, 13 August 2018 13:52
I am using Eclipselink Moxy Implementation of JAXB in my project to map complex XML to String Object using XmlAnyElement. For this I have implemented DomHandler named as LayoutHandler. I am using JAXB for resteasy web services deployed in JBoss 6.
I am facing Below issue intermittently -
  Exception [EclipseLink-50033] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b):
org.eclipse.persistence.exceptions.JAXBException
Exception Description: The DomHandlerConverter for DomHandler
[com.**.LayoutHandler] set on property [layoutXml] could not be
initialized.
Internal Exception: java.lang.ClassNotFoundException:
com.**.LayoutHandler from
BaseClassLoader@5c0b3ad0{vfs:///*/*/jboss-server/server/all/deployers/resteasy.deployer}
    While EclipseLink Moxy is instantiating JAXBContext using JAXBContext.newInstance(classes, properties)
After spending some time in debugging and analyzing the issue I could figure out that ClassLoader of resteasy is getting used to load LayoutHandler class instead of my application class loader(vfs://///jboss-server/server/all/deploy/app_name.ear/app_name.war/) which is causing the issue as its unable to find the LayoutHandler class.
Further debugging into org.eclipse.persistence.jaxb.JAXBContextFactory revealed that below two classes are getting passed to createContext() method of JAXBContextFactory -
    org.jboss.resteasy.plugins.providers.jaxb.JaxbCollection
    com.**.Model_class
public static javax.xml.bind.JAXBContext createContext(Class[] classesToBeBound, Map properties) throws JAXBException {
        ClassLoader loader = null;
        if (classesToBeBound.length > 0) {
            loader = classesToBeBound[0].getClassLoader();
        return createContext(classesToBeBound, properties, loader);
In above method classloader of first class is getting used to load the custom DomHandler later on.
When first element in array is model class at that time code is working fine as application context class loader is getting used but when the first element in array is JaxbCollection rest easy context class loader is getting used and its throwing mentioned exception.
This issue is occurring intermittently as order of elements in array is varying.
Previous Topic:Performance control for dinamic weaving
Next Topic:Using XmlJavaTypeAdapter(s) to map a third party class
Current Time: Sat Jul 19 11:39:54 EDT 2025
Powered by FUDForum. Page generated in 0.06951 seconds
