Home » Modeling » TMF (Xtext) » Using arrays Arrays and DotNotation in Expressions
Using arrays Arrays and DotNotation in Expressions [message #1793622] Sun, 12 August 2018 02:15 Go to next message
Hello.
I am trying to update my DSL to handle arrays and dot notation.
Having tried multiple different ways, and still being stuck, I am reaching out for some guidance.
Grammer on GitHub:
ExpressionDSL.xtext
Unit Test on GitHub (extract below):
ExpressionDSLParsingTest.xtend - testExpressionArray05()
Request:
Please help me change the DSL to be able to pass the unit test (below).
MWE2 - Error Message
1) [fatal] rule ruleArrayExp has non-LL(*) decision
2) Decision can match input using multiple alternatives:
error(211): ../org.xtext.example.expressiondsl/src-gen/org/xtext/example/expressiondsl/parser/antlr/internal/InternalExpressionDSLParser.g:892:2: [fatal] rule ruleArrayExp has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2.  Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
warning(200): ../org.xtext.example.expressiondsl/src-gen/org/xtext/example/expressiondsl/parser/antlr/internal/InternalExpressionDSLParser.g:1171:4: Decision can match input such as "RULE_ID" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
error(201): ../org.xtext.example.expressiondsl/src-gen/org/xtext/example/expressiondsl/parser/antlr/internal/InternalExpressionDSLParser.g:1171:4: The following alternatives can never be matched: 2
Unit Test Extract:
	var int intA;
	var int intB dim(10);
	struct structA;
		subf int subfA;
	endstruct;
	struct structB dim(10);
		subf int subfB;
	endstruct;
	struct structC dim(10);
		subf int subfC dim(20);
		struct subStructC dim(30);  // Nested Struct Array
			subf int subSubfC dim(40);
		endstruct;
	endstruct;
	def char funcTest;
	// Normal Assignment
	intA = intB;
	// Assign result of function
	intA = funcTest();
	intA = funcTest(1);
	intA = funcTest(2:3);
	// Arrays
	intA = intB(4);
	intA = intB(funcTest(5));
	// Qualified
	intA = structA;
	intA = structA.subfA;
	intA = structB(5);
	intA = structB(testFunc());
	intA = structB(6).subfB;
	intA = stuctC(7).subfC(8);
	intA = structC(9).subStructC(10).subSubf(11);
Re: Using arrays Arrays and DotNotation in Expressions [message #1793626 is a reply to message #1793622] Sun, 12 August 2018 06:22 Go to previous messageGo to next message
Please provide a minimal grammar.
Please solve the obvious ambiguity
A=ID |B=ID
First
Re: Using arrays Arrays and DotNotation in Expressions [message #1793627 is a reply to message #1793626] Sun, 12 August 2018 07:58 Go to previous messageGo to next message
Christian Dietrich wrote on Sun, 12 August 2018 10:22
A=ID |B=ID
First
The ambiguity, relates to the way I am trying to implement the ArrayExp,
it is conflicting with the "FunctionCall" rule.
Both uses the token sequence "ID '(' ')'"
Minimal Grammar:
grammar org.xtext.example.expressiondsl.ExpressionDSL with org.eclipse.xtext.common.Terminals
generate expressionDSL "http://www.xtext.org/example/expressiondsl/ExpressionDSL"
Model:
statements+=Statement*;
Statement:
VariableDef |
ConstDef |
StructDef |
FunctionDef |
FunctionCallStatement |
VariableAssignment
VariableDef:
'var' type=TYPE name=ValidID (options=Dim)? ';'
ConstDef:
'val' type=TYPE name=ValidID (options=Dim)? ';'
StructDef:
'struct' name=ValidID (options=Dim)? ';'
subFields+=(SubField)*
'endstruct' ';'
SubFieldDef:
('subf')? type=TYPE name=ValidID (options=Dim)? ';'
SubField:
SubFieldDef | StructDef
FunctionDef:
'def' type=TYPE name=ValidID ';'
VariableAssignment:
tgtvar=[VariableDef]
op=('=' | '+=' | '-=' | '*=' | '/=' | '**=' )
exp=Expression ';'
FunctionCallStatement:
'call'? call=FunctionCall ";"
FunctionCall:
=> ref=[FunctionDef]
(params+=Expression (':' params+=Expression)*)?
// ArrayExpOption1
//ArrayExp returns Expression:
// Primary (
// => ( {ArrayExp.left=current} '(' arrayDimensions=Expression ')' )
//ArrayExpOption2
//ArrayExp:
// => ref=[Variable] '(' index=Expression ')'
//ArrayExpOption3
// https://www.eclipse.org/forums/index.php/t/503752/
ArrayExp:
VariableArray |
StructArray |
SubFieldArray
VariableArray returns ArrayExp:
{VariableArray} => ref=[VariableDef] '(' arrayDimensions=Expression ')'
StructArray returns ArrayExp:
{StructArray} => ref=[StructDef] '(' arrayDimensions=Expression ')'
SubFieldArray returns ArrayExp:
{SubFieldArray} => ref=[SubFieldDef] '(' arrayDimensions=Expression ')'
DotExpression returns Ref:
=> StructArray ({DotExpression.ref=current} "." (tail=[SubFieldArray] | tail=[StructArray]) )*
Expression: Or;
Or returns Expression:
UnaryPlusMinusOrNot (
{Or.left=current} 'OR'
right=And
UnaryPlusMinusOrNot returns Expression:
FunctionExp |
( ({UnaryPlus} '+' | {UnaryMinus} '-' | {Not} 'NOT') expr=UnaryPlusMinusOrNot )
FunctionExp returns Expression:
// ArrayExp |
FunctionCall|
Primary
Primary returns Expression:
DotExpression |
ArrayExp |
// QualifiedName |
'(' Expression ')' |
Atomic
Atomic returns Expression:
{IntConstant} value=INT |
{StringConstant} value=STRING |
{BooleanConstant} value=BOOL
VariableOrConstRef:
VariableDef |
ConstDef |
StructDef |
SubField
Variable:
VariableDef |
StructDef |
SubField
Dim:
//Dimensions of Array (as in how many elements)
'DIM' '(' arrayDimensions=INT ')'
// Helper
// https://dslmeinte.wordpress.com/2014/09/11/ambiguitiy-in-xtext-grammars-part-2/
Named:
VariableDef |
ConstDef |
StructDef |
SubFieldDef |
FunctionDef
ValidID:
ID
//QualifiedName:
// ArrayExp ({ArrayExp.left=current} '.' tail=ArrayExp)*
terminal TYPE:
'int' | 'char' | 'bool'
terminal BOOL:
'true' | 'false'
Re: Using arrays Arrays and DotNotation in Expressions [message #1793628 is a reply to message #1793627] Sun, 12 August 2018 08:11 Go to previous messageGo to next message
if an array and a function call is synt. the same they have to be the same in grammar and ast
Re: Using arrays Arrays and DotNotation in Expressions [message #1793629 is a reply to message #1793628] Sun, 12 August 2018 08:13 Go to previous messageGo to next message
and i was referign to
ArrayExp:
VariableArray |
StructArray |
SubFieldArray
we have learned that ref=[XXXXXX] is short for ref=[XXXXXX|ID] which means the parser sees it at
ref=ID
you have
A= B|C;
B: ID;
C; ID;
which is ambigous for sure
Re: Using arrays Arrays and DotNotation in Expressions [message #1793662 is a reply to message #1793629] Mon, 13 August 2018 08:50 Go to previous messageGo to next message
Thanks for the Double reply.
Yes, the ambiguity in Option3 is my bad, should have sticked with Option2.
The issue I am facing is more related with Arrays vs Functions references in expressions
Array has one "parameter", while a Function can have Zero or More "parameters". Also Arrays can be a Qualified Name (aka DotNotation).
Arrays:
Array(INT) or Array(Expression)
Struct(INT) or Struct(INT).Subfield(INT) or Struct(INT).subStruct(INT)
Functions:
Function or Function() or Function(Parm1) or Function(Parm1:Parm2)
My current though is to collapse Variables, Arrays, QualifiedName and Functions into the "QualifiedRef" rule (refer code snippet below) and then do all the validations/scoping/proposals/outline with Xtend. But this feels like the wrong approach.
Attempt5 FAILED:
Option5 (refer to the code snippet below) does not pickup the QualifiedName rule (ref Screen Shot)
//ArrayExpOption5:
ParmSEP:
QualSEP:
VariableOrArrayOrFunc:
	ref=[Named|ValidID]
			params+=Expression (ParmSEP params+=Expression)* //One or More optional Parameters '(params1:params2)'
		)?   //Optional Parameter '(params)'
	')')? //Optional '()'
QualifiedRef:
	VariableOrArrayOrFunc ({QualifiedRefX.head=current} QualSEP tail=VariableOrArrayOrFunc)*
QualifiedRef |
Primary
Atomic
index.php/fa/33630/0/
Question:
For the LoveOfGoodness how do I do this! I am so frustrated with Expressions.
I know its not easy, but DUDE... this is getting out of hand. He says trying not to cry while curled up in a ball under his Desk.
[Updated on: Mon, 13 August 2018 08:53] by Moderator
Re: Using arrays Arrays and DotNotation in Expressions [message #1793664 is a reply to message #1793662] Mon, 13 August 2018 10:27 Go to previous messageGo to next message
you have no other change unless you introduce a different syntax
Re: Using arrays Arrays and DotNotation in Expressions [message #1793716 is a reply to message #1793664] Tue, 14 August 2018 10:01 Go to previous messageGo to next message
Christian Dietrich wrote on Mon, 13 August 2018 14:27
Unfortunately I can not change the syntax.
But surely xtext can handle this syntax as it is similair to Xtend's var.func.func(parm).
Re: Using arrays Arrays and DotNotation in Expressions [message #1793717 is a reply to message #1793716] Tue, 14 August 2018 10:03 Go to previous message
yes but xxxx() xxxxx(1) xxxxx(1,2) is all the same in xtend.
xtend does not differentiate
xxxx(1) => array
xxxx() => function
xxxx("Hello") => function
xxxxx(1,2) => function
=> you cannot distinguish at parse time
Previous Topic:How to order the elements in the Xtext Content Assist ?
Next Topic:Trigger validation manually
Current Time: Sun Jul 20 08:35:21 EDT 2025
Powered by FUDForum. Page generated in 0.05929 seconds
