Home » Newcomers » Newcomers » Eclipse won't run on Windows 10
Eclipse won't run on Windows 10 [message #1793615] Sat, 11 August 2018 15:29 Go to next message
I'm a java beginner. I downloaded Eclipse (eclipse-java-helios-SR1-win32-x86_64.zip was the zip file).
I have Java version 10.0.2 on my PC, Windows 10 64bit and I have Java in my path (can run java or javac from the command prompt anywhere). I've spent 2 hours googling for an answer and haven't found it so I hope you can help.
Every time I run sclipse.exe I get the message: An error has occured, see log file xxxxx. Below the contents of the log file. No idea how to fix this. Thanks for any advice.
!SESSION 2018-08-11 21:21:24.330 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=10.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2018-08-11 21:21:24.621
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503 [1]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1317)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1301)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:319)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
!ENTRY org.eclipse.osgi 4 0 2018-08-11 21:21:24.627
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar/ was not resolved.
!ENTRY org.eclipse.osgi 2 0 2018-08-11 21:21:24.630
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2018-08-11 21:21:24.630
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503 [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2018-08-11 21:21:24.630
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
!ENTRY org.eclipse.osgi 4 0 2018-08-11 21:21:24.635
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: Eclipse won't run on Windows 10 [message #1793617 is a reply to message #1793615] Sat, 11 August 2018 16:16 Go to previous messageGo to next message
Helios is a nearly 8 year old release. Get Photon, specifically http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/photon/R/eclipse-java-photon-R-win32-x86_64.zip .
Re: Eclipse won't run on Windows 10 [message #1793624 is a reply to message #1793617] Sun, 12 August 2018 05:56 Go to previous messageGo to next message
Thanks for your reply!
I did download Photon and deleted as it was only for javascript or web-based Java. Am I wrong?
Re: Eclipse won't run on Windows 10 [message #1793625 is a reply to message #1793617] Sun, 12 August 2018 06:20 Go to previous messageGo to next message
I installed Photon again and found the Eclipse IDE. Thank you!
Re: Eclipse won't run on Windows 10 [message #1809568 is a reply to message #1793625] Thu, 18 July 2019 06:14 Go to previous messageGo to next message
I prefer the zip version, because there is no need to run any installer. Moreover, you can simply delete the entire Eclipse directory when it is no longer needed (without running any un-installer). You are free to move or rename the directory. You can install (unzip) multiple copies of Eclipse in the same machine.
[Updated on: Tue, 29 December 2020 10:41] by Moderator
Re: Eclipse won't run on Windows 10 [message #1830181 is a reply to message #1793615] Mon, 20 July 2020 02:16 Go to previous message
i LIKE ITS ZIP VERSION BUT THERE ARE SOME PROBLEM. WHEN I EXTRACT AND I CANT INSTALL IT.
Previous Topic:i have errors on build gradle
Next Topic:Eclipse WindowBuilder with PDE
Current Time: Sat Jul 19 08:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.11994 seconds
