Home » Modeling » TMF (Xtext) » mismatched input '<EOF>' expecting 'configuration error type
mismatched input '<EOF>' expecting 'configuration error type [message #1792956] Thu, 26 July 2018 09:40 Go to next message
I tried the code that is shown below to create an xtext resource/file. It seems to work fine but it shows an error when I close the eclipse runtime instance and rerun it. The error is "mismatched input '<EOF>' expecting 'configuration:'".
The file is correct by syntax and with a little bit of research I found that it is an encoding problem. Current encoding of the file is Cp1252. When I right click on the xtext file and change the encoding to whatever else (through the properties dialog box), the error goes away no matter what type of encoding I choose. So, do you also think that the error is for encoding??? or do you have any suggestion to refine the code below to force it create a well-encoded xtext file and avoid the error?
	private static Resource createandSaveResource(String metadataPath) {
		ResourceSet rs = new ResourceSetImpl();
		Resource resource = rs.createResource(URI.createFileURI(metadataPath));
		Metadata model = MetadataDSLFactory.eINSTANCE.createMetadata();
		Configuration config = MetadataDSLFactory.eINSTANCE.createConfiguration();
		model.setConfig(config);
		resource.getContents().add(model);
		try {
			resource.save(Collections.EMPTY_MAP);
		} catch (IOException e) {
			e.printStackTrace();
			return null;
		return resource;
Thanks a lot,
Best,
Parsa
[Updated on: Thu, 26 July 2018 09:45] by Moderator
Re: mismatched input '<EOF>' expecting 'configuration error type [message #1792959 is a reply to message #1792956] Thu, 26 July 2018 09:49 Go to previous messageGo to next message
for me this sounds more like a utf-8/bom problem
https://bugs.eclipse.org/bugs/show_bug.cgi?id=390308
=> did you debug whats actually in the beginning of the file? can you reproduce this with the greeting example?
Re: mismatched input '<EOF>' expecting 'configuration error type [message #1793006 is a reply to message #1792959] Fri, 27 July 2018 08:26 Go to previous messageGo to next message
Hi Christian,
You're right. Is there any solution or workaround to it?
Parsa
Re: mismatched input '<EOF>' expecting 'configuration error type [message #1793010 is a reply to message #1793006] Fri, 27 July 2018 09:00 Go to previous message
no i dont any.
Previous Topic:Content Assist not triggered by CTRL+SPACE inside the Orion web editor
Next Topic:Active Annotations: Import type references made in template strings defined in method
Current Time: Sat Jul 19 20:12:18 EDT 2025
Powered by FUDForum. Page generated in 0.06044 seconds
