Home » Modeling » TMF (Xtext) » Using Xtext reserved wording withing DSL
Using Xtext reserved wording withing DSL [message #1792933] Thu, 26 July 2018 03:22 Go to next message
Hello.
Hoping for some advice please.
Currently I am trying to write rules to deal with "Compiler Directives" as defined here.
The basic layout is:
'/' directive (directive_options)?
My one of my initial attempts:
>>Insert Screenshot of Grammar Snippet<<<
CompilerDirectiveTITLE:
'/TITLE' name=ID
CompilerDirectiveEJECT:
{CompilerDirectiveEJECT}
'/EJECT'
CompilerDirectiveDEFINE:
'/DEFINE' name=ID
CompilerDirectiveUNDEFINE:
'/UNDEFINE' name=ID
CompilerDirectiveEOF:
{CompilerDirectiveEOF}
'/EOF'
The issue::
When trying to specify the "EOF" directive, the grammer does not compile.
>>>Insert Screenshot of EOF directive<<<
	'/EOF'
>>>Insert Screenshot of MWE2 Error<<<
Parser.g:104:3: The following alternatives can never be matched: 2
Request:
Is it possible to have '/EOF' in the DSL?
EDIT:
Seems that Images are not being uploaded. Replaced with code snippet.
[Updated on: Thu, 26 July 2018 03:32] by Moderator
Re: Using Xtext reserved wording withing DSL [message #1792935 is a reply to message #1792933] Thu, 26 July 2018 03:27 Go to previous messageGo to next message
hi, please provide a minimal grammar and testmodel showing your problem
Re: Using Xtext reserved wording withing DSL [message #1792936 is a reply to message #1792935] Thu, 26 July 2018 03:34 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 26 July 2018 07:27
Done, please refer to the first post.
Edits made, as screenshots did not upload during initial post.
Re: Using Xtext reserved wording withing DSL [message #1792938 is a reply to message #1792936] Thu, 26 July 2018 03:43 Go to previous messageGo to next message
i want i minimal grammar i can simply c&p & run.
the grammar
	'/EOF'
works fine
Re: Using Xtext reserved wording withing DSL [message #1792946 is a reply to message #1792938] Thu, 26 July 2018 05:28 Go to previous messageGo to next message
isn't it just that (according to the PNG: "CompilerDirectiveEOF hidden():")
there is a hidden() which is not mentioned in this conversation so far?
Re: Using Xtext reserved wording withing DSL [message #1792958 is a reply to message #1792946] Thu, 26 July 2018 09:46 Go to previous messageGo to next message
Thanks for the responses.
It seems that the problem is related to making the DSL case insensitive. By adding the "ignoreCase = true" to the parseGenerator.
		language = StandardLanguage {
			name = "org.xtext.example.directivedsl.DirectiveDSL"
			fileExtensions = "dirdsl"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
			junitSupport = {
				junitVersion = "5"
			parserGenerator = {
//				debugGrammar = true
				options = {
					ignoreCase = true
//			scopeProvider = {
//				ignoreCase = true
I created a temp GitHub repo for the language.
To for easier C&C (or Clone) and running.
https://github.com/zs6jce/example-DirectiveDSL
Re: Using Xtext reserved wording withing DSL [message #1792962 is a reply to message #1792958] Thu, 26 July 2018 10:43 Go to previous message
created https://github.com/eclipse/xtext-core/issues/804
Previous Topic:Whitespace without newlines
Next Topic:Access all Resources in Eclipse(Xtext) Project
Current Time: Sun Jul 20 08:13:01 EDT 2025
Powered by FUDForum. Page generated in 0.04349 seconds
