Home » Newcomers » Newcomers » Error Deploying Persistence EJB jar in eclipse Workspace (Error Deploying Persistence EJB jar ,in newly created workspace)
Error Deploying Persistence EJB jar in eclipse Workspace [message #1792609] Fri, 20 July 2018 04:06
I am getting following error .
Server :Weblogic and Java 1.6
Unable to deploy the persistence.jar due to missing Remote class.But When I checked I can able to see the compiled BeanRemote.class file in the build/classes folder.
Can you please help me with this.This happens when I try to create a new workspace.
!ENTRY org.eclipse.equinox.event 4 0 2018-07-20 13:18:10.781
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.menu.impl.PopupMenuImpl@559ff07 (elementId: org.eclipse.wst.server.ui.ServersView, tags: [menuContribution:popup, popup:org.eclipse.wst.server.ui.ServersView], contributorURI: null) (widget: Menu {Ne&w, |, &Start, S&top, &Restart, Remove Delete, |, Compare, Select Left File, Select Left Folder, |, SVN Checkout..., SVN Update, SVN Commit..., SVN Diff, SVN Diff, SVN Diff with previous version, SVN Show Log, SVN Repo-browser, SVN Check for modifications, SVN Revision graph, SVN Resolve..., SVN Update to revision..., SVN Rename..., SVN Delete..., SVN Revert..., SVN Clean up..., SVN Get lock..., SVN Release lock..., SVN Branch/tag..., SVN Switch..., SVN Merge..., SVN Export..., SVN Blame..., SVN Add..., SVN Copy URL to clipboard, SVN Create patch..., SVN Apply patch..., SVN Properties, SVN Settings, SVN Help, SVN About, |, Git Sync..., Git Commit..., Hg Commit..., |, Properties Alt+Enter}, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, mnemonics: null) (enabled: true) (context: popup:org.eclipse.wst.server.ui.ServersView, variables: null), Widget=Menu {Ne&w, |, &Start, S&top, &Restart, Remove Delete, |, Compare, Select Left File, Select Left Folder, |, SVN Checkout..., SVN Update, SVN Commit..., SVN Diff, SVN Diff, SVN Diff with previous version, SVN Show Log, SVN Repo-browser, SVN Check for modifications, SVN Revision graph, SVN Resolve..., SVN Update to revision..., SVN Rename..., SVN Delete..., SVN Revert..., SVN Clean up..., SVN Get lock..., SVN Release lock..., SVN Branch/tag..., SVN Switch..., SVN Merge..., SVN Export..., SVN Blame..., SVN Add..., SVN Copy URL to clipboard, SVN Create patch..., SVN Apply patch..., SVN Properties, SVN Settings, SVN Help, SVN About, |, Git Sync..., Git Commit..., Hg Commit..., |, Properties Alt+Enter}, AttName=children, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.HandledMenuItemImpl@27014097 (elementId: ContextQuickie.commands.TortoiseHg.TortoiseHgCommand, tags: [], contributorURI: null) (widget: MenuItem {Hg Commit...}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer@36a59d8, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: Hg Commit..., iconURI: platform:/plugin/ContextQuickie/icons/TortoiseGit/menucommit.png, tooltip: null, enabled: true, selected: false, type: Push) (mnemonics: null) (wbCommand: null), EventType=ADD, Position=53} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@1818c0a0
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:341)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.mergeIntoModel(ContributionRecord.java:250)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.processAddition(MenuManagerRenderer.java:554)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.generateContributions(MenuManagerRenderer.java:529)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.processContributions(MenuManagerRenderer.java:494)
at org.eclipse.ui.internal.PopupMenuExtender.addMenuContributions(PopupMenuExtender.java:409)
at org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(PopupMenuExtender.java:381)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:333)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:466)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:461)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:493)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:255)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1118)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:5023)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4691)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1633)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2117)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5050)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:262)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4221)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.ui.internal.commands.SlaveCommandService.registerElementForCommand(SlaveCommandService.java:311)
at org.eclipse.ui.internal.commands.SlaveCommandService.registerElementForUpdate(SlaveCommandService.java:395)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.fill(HandledContributionItem.java:324)
at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:724)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:806)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:665)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java:1164)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.processContents(MenuManagerRenderer.java:636)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.subscribeTopicChildAdded(MenuManagerRenderer.java:313)
at sun.reflect.GeneratedMethodAccessor19.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 67 more
!ENTRY org.eclipse.equinox.event 4 0 2018-07-20 13:18:14.686
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.menu.impl.PopupMenuImpl@559ff07 (elementId: org.eclipse.wst.server.ui.ServersView, tags: [menuContribution:popup, popup:org.eclipse.wst.server.ui.ServersView], contributorURI: null) (widget: Menu {Ne&w, |, &Start, S&top, &Restart, Remove Delete, |, Compare, Select Left File, Select Left Folder, |, SVN Checkout..., SVN Update, SVN Commit..., SVN Diff, SVN Diff, SVN Diff with previous version, SVN Show Log, SVN Repo-browser, SVN Check for modifications, SVN Revision graph, SVN Resolve..., SVN Update to revision..., SVN Rename..., SVN Delete..., SVN Revert..., SVN Clean up..., SVN Get lock..., SVN Release lock..., SVN Branch/tag..., SVN Switch..., SVN Merge..., SVN Export..., SVN Blame..., SVN Add..., SVN Copy URL to clipboard, SVN Create patch..., SVN Apply patch..., SVN Properties, SVN Settings, SVN Help, SVN About, |, Git Sync..., Git Commit..., Hg Commit..., |, Properties Alt+Enter}, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, mnemonics: null) (enabled: true) (context: popup:org.eclipse.wst.server.ui.ServersView, variables: null), Widget=Menu {Ne&w, |, &Start, S&top, &Restart, Remove Delete, |, Compare, Select Left File, Select Left Folder, |, SVN Checkout..., SVN Update, SVN Commit..., SVN Diff, SVN Diff, SVN Diff with previous version, SVN Show Log, SVN Repo-browser, SVN Check for modifications, SVN Revision graph, SVN Resolve..., SVN Update to revision..., SVN Rename..., SVN Delete..., SVN Revert..., SVN Clean up..., SVN Get lock..., SVN Release lock..., SVN Branch/tag..., SVN Switch..., SVN Merge..., SVN Export..., SVN Blame..., SVN Add..., SVN Copy URL to clipboard, SVN Create patch..., SVN Apply patch..., SVN Properties, SVN Settings, SVN Help, SVN About, |, Git Sync..., Git Commit..., Hg Commit..., |, Properties Alt+Enter}, AttName=children, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.HandledMenuItemImpl@44958dcf (elementId: ContextQuickie.commands.TortoiseHg.TortoiseHgCommand, tags: [], contributorURI: null) (widget: MenuItem {Hg Commit...}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer@36a59d8, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: Hg Commit..., iconURI: platform:/plugin/ContextQuickie/icons/TortoiseGit/menucommit.png, tooltip: null, enabled: true, selected: false, type: Push) (mnemonics: null) (wbCommand: null), EventType=ADD, Position=53} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@1818c0a0
!STACK 0
... 67 more
!ENTRY oracle.eclipse.tools.weblogic 1 2000 2018-07-20 13:18:35.830
!MESSAGE Stopped WebLogic Server Monitor [test1@localhost:7001, Version:10.3.6.0]
!ENTRY oracle.eclipse.tools.weblogic 1 2000 2018-07-20 13:18:36.993
!MESSAGE Releasing deployment manager :[Oracle WebLogic Server 11gR1 (10.3.6) [test1]]@746082874
  • Attachment: .log
    (Size: 999.62KB, Downloaded 114 times)
Previous Topic:pydev issue
Next Topic:Accessing Eclipse Files
Current Time: Sat Jul 19 13:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.30107 seconds
