Home » Eclipse Projects » P2 » Download eclipse plugins from update site with out eclipse command line(Download eclipse plugins from update site with out eclipse command line)
Download eclipse plugins from update site with out eclipse command line [message #1792555] Thu, 19 July 2018 09:36 Go to next message
can i download eclipse plugins from update site with out eclipse.exe/eclipse in command line
am able to download plugins with eclipse.exe/eclipse below command: eclipse -application org.eclipse.equinox.p2.artifact.repository.mirrorApplication -source $1 -destination $2
Raju
[Updated on: Thu, 19 July 2018 09:37] by Moderator
Re: Download eclipse plugins from update site with out eclipse command line [message #1792561 is a reply to message #1792555] Thu, 19 July 2018 10:17 Go to previous messageGo to next message
You could download the artifacts.xml/artifacts.jar/artifacts.xml.xz, which describe the different binary artifacts available, and then process them to identify the different artifact files.
What are you trying to do?
Brian.
Re: Download eclipse plugins from update site with out eclipse command line [message #1792600 is a reply to message #1792561] Fri, 20 July 2018 02:34 Go to previous messageGo to next message
Hi Brian,
Thanks for the replay.
we have a cloud machine. where i want to place my latest plug-ins. all consumers will download from cloud machine and place it in dropins folder.
want to download plugins using hot-fix url(download.xxxxx.site.xml) and place it in cloud machine.
Raju
Re: Download eclipse plugins from update site with out eclipse command line [message #1792647 is a reply to message #1792600] Fri, 20 July 2018 09:53 Go to previous messageGo to next message
Why not just use p2 and the normal check for updates mechanism?
Re: Download eclipse plugins from update site with out eclipse command line [message #1792822 is a reply to message #1792647] Tue, 24 July 2018 09:25 Go to previous messageGo to next message
Hi Brian,
my cloud machine doesn't contain eclipse . checking for the script to download plugins given update site url.
Re: Download eclipse plugins from update site with out eclipse command line [message #1792823 is a reply to message #1792822] Tue, 24 July 2018 09:41 Go to previous message
So you produce a build on your development box. You want a way to push that site to your cloud machine. Your consumers will download this update from the cloud machine.
If I have that right, then p2 is the recommended approach. p2 doesn't require a smart-server -- it just downloads files via normal HTTP. p2 downloads associated metadata (contents.xml and artifacts.xml), which describe the contents of the site, and then reconciles against its current installation to determine which plugins and features should be downloaded and installed.
Alternatively you can do what I describe in my first answer.
If I misunderstood, please clarify how your setup works.
Brian.
Previous Topic:authentication
Next Topic:Cannot open Eclipse Marketplace
Current Time: Sun Jul 20 14:57:28 EDT 2025
Powered by FUDForum. Page generated in 0.04665 seconds
