Home » Eclipse Projects » Kura » Can Kura work on x86 based linux system?
Can Kura work on x86 based linux system? [message #1792491] Wed, 18 July 2018 11:44 Go to next message
Does Kura include codes for connect to simens S7?
Re: Can Kura work on x86 based linux system? [message #1792498 is a reply to message #1792491] Wed, 18 July 2018 13:58 Go to previous messageGo to next message
at the moment Kura can support ARM based and x86_64 based devices.
Yes, Kura has a driver for s7. Here the reference to the code: https://github.com/eclipse/kura/tree/develop/kura/org.eclipse.kura.driver.s7plc.provider
And here the marketplace entry: https://marketplace.eclipse.org/content/s7-driver-kura
Matteo
Re: Can Kura work on x86 based linux system? [message #1792533 is a reply to message #1792498] Thu, 19 July 2018 04:12 Go to previous messageGo to next message
that looks great!
Which files I should download for x86_64 ubuntu 16? as I see download for Raspberry Pi version, is this version can also run on personal computer?
Re: Can Kura work on x86 based linux system? [message #1792535 is a reply to message #1792533] Thu, 19 July 2018 04:25 Go to previous messageGo to next message
Kura is not meant to be installed directly on a PC. There you can use the User Workspace that is executed in the Eclipse IDE and will help you with the development.
The supported platforms are the ones listed in the downloads page: https://www.eclipse.org/kura/downloads.php
There you can find also the user workspace.
Matteo
Re: Can Kura work on x86 based linux system? [message #1792540 is a reply to message #1792535] Thu, 19 July 2018 05:29 Go to previous messageGo to next message
Hello Matteo,
I do not understand Eclipse User Workspace very well, is that mean Kura must run under Eclipse IDE? Is that possible to export to .war to run on Tomcat or docker etc independently?
Re: Can Kura work on x86 based linux system? [message #1792541 is a reply to message #1792540] Thu, 19 July 2018 05:32 Go to previous messageGo to next message
on target hardware (mainly raspberry), Kura runs natively on a Java virtual machine.
On a PC, since that is not a target environment, there is the development environment that allows you to use a limited version of Kura inside the Eclipse IDE just for development purposes.
Kura can be run in the no network version in a docker container, but is not a supported environment, at the moment.
Matteo
Re: Can Kura work on x86 based linux system? [message #1792542 is a reply to message #1792541] Thu, 19 July 2018 05:51 Go to previous messageGo to next message
As it's built by Java, should be very easy to run on windows or linux based x86 PC, If there is a commercial version for sell I'd like to have a look, thanks.
Re: Can Kura work on x86 based linux system? [message #1792548 is a reply to message #1792542] Thu, 19 July 2018 08:05 Go to previous messageGo to next message
it could run, but you have to consider that in its full version Kura is a network manager. Being so, at framework boot, Kura will start managing your host device network interfaces and probably that is something you don't want in your PC.
There exist commercially supported versions of Kura. I cannot here reference them, but you should be able to find them by googling.
Matteo
Re: Can Kura work on x86 based linux system? [message #1792553 is a reply to message #1792548] Thu, 19 July 2018 09:16 Go to previous message
ok, thank you, I will check it.
Previous Topic:I2C
Next Topic:Sending MQTT to AWS NOT WORKING
Current Time: Sun Jul 20 09:56:32 EDT 2025
Powered by FUDForum. Page generated in 0.24680 seconds
