Edit popup issue [message #178932] |
Tue, 25 March 2008 12:49  |
I have modified my generated code so that when user double-click on a
label, a pop is displayed to edit it.
Here is the error displayed when I execute the pressedOk button action :
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.performRequest(GraphicalEditPart.java:1098)
at
org.eclipse.gef.tools.SelectEditPartTracker.performOpen(Sele ctEditPartTracker.java:187)
at
org.eclipse.gef.tools.SelectEditPartTracker.handleDoubleClic k(SelectEditPartTracker.java:131)
at
org.eclipse.gef.tools.AbstractTool.mouseDoubleClick(Abstract Tool.java:944)
at
org.eclipse.gef.tools.SelectionTool.mouseDoubleClick(Selecti onTool.java:501)
at org.eclipse.gef.EditDomain.mouseDoubleClick(EditDomain.java: 204)
at
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse DoubleClicked(DomainEventDispatcher.java:285)
at
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDoubl eClick(LightweightSystem.java:508)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:182)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: java.lang.IllegalStateException: Cannot modify resource set
without a write transaction
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:322)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:284)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:266)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:222)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
at com.clearsy.eventB.impl.InvariantImpl.setLabel(InvariantImpl .java:153)
at
com.clearsy.eventB.machinecontent.diagram.edit.commands.Inva riantUpdateCommand.setValues(InvariantUpdateCommand.java:52)
at
com.clearsy.eventB.machinecontent.diagram.edit.commands.Inva riantUpdateCommand.execute(InvariantUpdateCommand.java:79)
at
org.eclipse.gmf.runtime.diagram.ui.commands.CommandProxy.doE xecuteWithResult(CommandProxy.java:49)
at
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:134)
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
... 37 more
Can somebody help me please ?
Thanks for your help.
Philippe
Re: Edit popup issue [message #179061 is a reply to message #179008] |
Wed, 26 March 2008 05:50   |
Hi Alex, thank you.
Here is my architecture :
ELEMENTEditPart.java :
protected void createDefaultEditPolicies() {
super.createDefaultEditPolicies();
installEditPolicy(EditPolicyRoles.OPEN_ROLE, createOpenEditPolicy());
private EditPolicy createOpenEditPolicy() {
return new ELEMENTDialogOpenEditPolicy((ELEMENT) ((View)
getModel()).getElement(), getViewer(), getEditingDomain());
ELEMENTDialogOpenEditPolicy extends OpenEditPolicy
protected Command getOpenCommand(Request request) {
if (null != _ELEMENT) {
Shell shell = viewer.getControl().getShell();
ELMENTEditDialog dialog = new
InvariantEditDialog(invariant,shell);
if (dialog.open() == Window.OK)
return new ELEMENTUpdateCommand(invariant,
dialog.getData());
return null;
ELEMENTUpdateCommand extends Command
public void execute()
getOldValues();
setValues();
So, my command extends Command class. What must I modify in my
architecture ?
Philippe
Alex Shatalin a écrit :
> Hello Philippe,
> Subclass AbstractTransactionalCommand to perform your operation.
> Alex Shatalin
Re: Edit popup issue [message #179079 is a reply to message #179061] |
Wed, 26 March 2008 07:13   |
Hi Philippe,
ElementUpdateCommand should subclass AbstractTransactionalCommand. The
methods that return GEF commands should wrap your command into
ICommandProxy.
Boris
Philippe BLANC wrote:
> Hi Alex, thank you.
> dialog.getData());
> return null;
> getOldValues();
> setValues();
> architecture ?
> Regards,
> Philippe
>> Hello Philippe,
>> Alex Shatalin
Re: Edit popup issue [message #179237 is a reply to message #179079] |
Wed, 26 March 2008 11:36  |
Thank you Boris and Alex, it works! Here is my implementation :
if (null != ELEMENT) {
ELEMENTEditDialog dialog = new
ELEMENTEditDialog(invariant,shell);
Map data = dialog.getData();
return new ICommandProxy(new
InvariantUpdateCommand(editingDomain,ELEMENT,dialog.getData( )));
return null;
ELEMENTUpdateCommand extends AbstractTransactionalCommand
public InvariantUpdateCommand(TransactionalEditingDomain domain,
ELEMENT elt, Map data) {
super(domain,"ELEMENTUpdateCommand",null);
this.ELEMENT = elt;
protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
getOldValues();
setValues();
return CommandResult.newOKCommandResult();
Philippe
Boris Blajer a écrit :
> Hi Philippe,
> ICommandProxy.
> Best regards,
> Boris
>> Hi Alex, thank you.
>> dialog.getData());
>> return null;
>> getOldValues();
>> setValues();
>> architecture ?
>> Regards,
>> Philippe
>>> Hello Philippe,
>>> Alex Shatalin
FUDForum. Page generated in 0.05730 seconds
