Home » Eclipse Projects » GlassFish Tools » Unable to install Glassfish plugin on Eclipse Photon & Oxygen(Unable to install Glassfish plugin on Eclipse Photon & Oxygen)
Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792116] Wed, 11 July 2018 15:40 Go to next message
index.php/fa/33365/0/I'm trying to set up the Glassfish server on Eclipse but have had no luck. I'm on Java version 10.0.1
Steps:
1. Open Eclipse
2. Go to Help > Eclipse Marketplace
3. Search for GlassFish
4. Click on Install
5. Glassfish Tools and oracle.eclipse.tools.glassfish is selected. Click Confirm.
Result:
Installation progress bar says "Cannot perform operation. Computing alternate solutions, may take awhile." It eventually finishes and says "Cannot complete the request. See error logs for details."
Not sure where to find the error logs. I get this same error on both Eclipse Photon & Oxygen.
index.php/fa/33367/0/
index.php/fa/33368/0/
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792125 is a reply to message #1792116] Thu, 12 July 2018 00:31 Go to previous messageGo to next message
We too would need to see the error log for details. Type "Error Log" in the "Quick Access" search box to the upper right of the perspective for the view of the error log.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792155 is a reply to message #1792125] Thu, 12 July 2018 04:29 Go to previous messageGo to next message
If you don't have an Error Log view, the file itself is at <workspace location>/.metadata/.log . The view would only be present if you had the Plug-in Development Environment installed.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792240 is a reply to message #1792116] Fri, 13 July 2018 02:21 Go to previous messageGo to next message
I have faced the same issue with Eclipse Photon 4.8.0
Attached the error log.
  • Attachment: ErrorLog.txt
    (Size: 12.63KB, Downloaded 1179 times)
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1793839 is a reply to message #1792116] Thu, 16 August 2018 16:16 Go to previous messageGo to next message
Any closer to figuring this out? I'm having the same issue. Error log attached.
  • Attachment: log.txt
    (Size: 25.03KB, Downloaded 620 times)
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1794241 is a reply to message #1793839] Mon, 27 August 2018 19:05 Go to previous messageGo to next message
I have the same problem. Any news on that?
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1795067 is a reply to message #1792116] Thu, 13 September 2018 18:50 Go to previous messageGo to next message
I too am unable to download glassfish tools from the eclipse marketplace in Oxygen or Photon. It works in Neon.
Are we any closer to a resolution?
I found a post about a similar issue in the past regarding a broken web cache for the marketplace?
community.oracle.com/thread/3933198
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1797004 is a reply to message #1792116] Tue, 23 October 2018 18:59 Go to previous messageGo to next message
Is there any news on this? I'm experiencing the same problem in Eclipse for Java EE 4.9
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1800229 is a reply to message #1797004] Fri, 21 December 2018 10:00 Go to previous messageGo to next message
Having the same problem with Eclipse Luna. Running on Windows10.
In addition to this, there is no link on the Server view, where you can add additional servers.
index.php/fa/34548/0/
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1800767 is a reply to message #1800229] Mon, 07 January 2019 22:03 Go to previous messageGo to next message
I am using Eclipse 2018 12.I am trying to install GlassFish 5.0 using eclipse marketplace(under help) but the option available only supports GlassFish4.x.
Can anyone help ?
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1800768 is a reply to message #1800767] Mon, 07 January 2019 22:10 Go to previous messageGo to next message
As you are on the latest, you might try http://download.eclipse.org/glassfish-tools/1.0.0/repository ,
the Update Site for the tools now that they are a project at the Eclipse Foundation. Work with that URL from the Help->Install New Software menu in Eclipse.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1805050 is a reply to message #1800768] Thu, 04 April 2019 21:01 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Mon, 07 January 2019 22:10
This worked for eclipse 2018-09 and 2018-12, but no longer works with 2019-03. I tried to submit a bug report, but that is blocked. Eclipse Foundation manages GlassFish now. How about we either restore the ability to install the version published to the marketplace, and fix the one in the official eclipse.org link.
Anyone?
Error:
Cannot complete the install because one or more required items could not be found.
Software being installed: GlassFish Tools 1.0.0.201806111515 (org.eclipse.glassfish.tools.feature.group 1.0.0.201806111515)
Missing requirement: GlassFish Tools 1.0.0.201806111515 (org.eclipse.glassfish.tools.feature.group 1.0.0.201806111515) requires 'org.eclipse.equinox.p2.iu; org.eclipse.sapphire.feature.group [9.1.0,10.0.0)' but it could not be found
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1805051 is a reply to message #1800768] Thu, 04 April 2019 21:02 Go to previous messageGo to next message
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1809360 is a reply to message #1805050] Sun, 14 July 2019 15:39 Go to previous messageGo to next message
You'll need to add the Sapphire update site, http://download.eclipse.org/sapphire/9.1.1/repository , to your list of Available Software Sites so that it can be found.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1809442 is a reply to message #1809360] Tue, 16 July 2019 05:18 Go to previous messageGo to next message
You guys are my rescuers, I had a similar problem for several days, I did everything exactly with your advice and now everything is fine.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1836887 is a reply to message #1809442] Sun, 17 January 2021 14:28 Go to previous messageGo to next message
I was struggling a lot to find a sol, thus I decided to uninstall eclipse Oxygene and install Eclipse neon it works fine now, https://www.eclipse.org/downloads/packages/release/neon/3
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1838627 is a reply to message #1836887] Tue, 02 March 2021 11:16 Go to previous messageGo to next message
A solution was found for current releases, though. Why go back to 4 year old releases?
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1844333 is a reply to message #1792116] Thu, 09 September 2021 09:52 Go to previous messageGo to next message
Please follow the below steps for configuration of Glass-Fish Server With Eclipse IDE.
Go to the Help Section Of Eclipse.
Choose Option Install New Software.
Paste the below given link in the Text Box of Work With option.
Link: http://download.eclipse.org/glassfish-tools/1.0.1/repository/
Then Proceed with Confirm OK OK.
Now It will take some time to install and automatically ask for Restart.
Success.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1855960 is a reply to message #1844333] Fri, 11 November 2022 13:16 Go to previous message
Hi everyone,
I have a similar issue. I tried to install GlassFish using the Eclipse Marketplace. When clicking on "Install", I get an error message telling me "No repository found". If I check the url, it tells me "Not found".
Can anyone tell me please how I can install GlassFish Tools (Eclipse version 4.25.0, don't know if this matters)?
Thanks in advance!
Martin
Previous Topic:Cannot download glassfish tools 1.0.1
Current Time: Sun Jul 20 16:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.05411 seconds
