Home » Modeling » TMF (Xtext) » Problems using AbstractLanguageServerTest
Problems using AbstractLanguageServerTest [message #1791888] Fri, 06 July 2018 10:59 Go to next message
I created a new DSL with the Xtext wizard. I selected language server, Gradle build and JUnit 5 support.
I added a language server test in the <mydsl>.ide project in the source folder src/test/java.
The test class sublasses the AbstractLanguageServerTest and gives the language id in the constructor.
All my tests fail because of this NPE:
	at org.eclipse.xtext.testing.AbstractLanguageServerTest.lambda$initialize$1(AbstractLanguageServerTest.java:289)
	at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
	at org.eclipse.xtext.testing.AbstractLanguageServerTest.initialize(AbstractLanguageServerTest.java:291)
	at org.eclipse.xtext.testing.AbstractLanguageServerTest.initialize(AbstractLanguageServerTest.java:281)
	at org.eclipse.xtext.testing.AbstractLanguageServerTest.initializeContext(AbstractLanguageServerTest.java:814)
	at org.eclipse.xtext.testing.AbstractLanguageServerTest.testCompletion(AbstractLanguageServerTest.java:775)
	at de.abas.screen.ls.ide.tests.completion.ScreenServiceCompletionTest.testEndCompletion(ScreenServiceCompletionTest.java:23)
I use Eclipse Photon and Xtext 2.14.0.
I fixed the build already like it is mentioned here: https://github.com/eclipse/xtext/issues/1231
My DSL is just the Greetings tutorial DSL and one of the failing tests is this:
@Test
	def void test02_openFile() {
		initialize()
		val file = 'hello.mydsl'.writeFile("")
		file.open('''
			Hello Xtext!
		Assertions.assertTrue(diagnostics.get(file).empty, "There're issues in file 'hello.mydsl'.")
Everything works but not my test. What am I doing wrong?
Re: Problems using AbstractLanguageServerTest [message #1791890 is a reply to message #1791888] Fri, 06 July 2018 11:16 Go to previous messageGo to next message
can you please give more context. i cannot reproduce.
(1) did you add the mydsl.ide project to the test project
(2) is lsp4j and lsp4j.jsonrpc on the dependencies of your test project?
Re: Problems using AbstractLanguageServerTest [message #1791891 is a reply to message #1791890] Fri, 06 July 2018 11:19 Go to previous messageGo to next message
besides that: debugging always helps to analyse
Re: Problems using AbstractLanguageServerTest [message #1791892 is a reply to message #1791891] Fri, 06 July 2018 11:26 Go to previous messageGo to next message
Attached is my build.grade of the <mydsl>.ide project.
  • Attachment: build.gradle
    (Size: 1.97KB, Downloaded 107 times)
Re: Problems using AbstractLanguageServerTest [message #1791893 is a reply to message #1791892] Fri, 06 July 2018 11:27 Go to previous messageGo to next message
i miss e.g.
compile project(':de.abas.screen.ls.ide')
Re: Problems using AbstractLanguageServerTest [message #1791894 is a reply to message #1791893] Fri, 06 July 2018 11:29 Go to previous messageGo to next message
I added the test to the project de.abas.screen.ls.ide itself.
Re: Problems using AbstractLanguageServerTest [message #1791895 is a reply to message #1791894] Fri, 06 July 2018 11:35 Go to previous messageGo to next message
I added a screenshot of my project layout.
Re: Problems using AbstractLanguageServerTest [message #1791896 is a reply to message #1791895] Fri, 06 July 2018 11:42 Go to previous messageGo to next message
When I debug I can see that the field languageServer of the class AbstractLanguageServerTest is always null. What could be the problem?
Re: Problems using AbstractLanguageServerTest [message #1791897 is a reply to message #1791894] Fri, 06 July 2018 11:43 Go to previous messageGo to next message
i still cannot reproduce.
are you sure you got language id and file extension correct?
Re: Problems using AbstractLanguageServerTest [message #1791898 is a reply to message #1791897] Fri, 06 July 2018 11:45 Go to previous messageGo to next message
Do you recommend to add an extra test project or is it ok to add the test inside the test source folder of the <mydsl>.ide project?
Re: Problems using AbstractLanguageServerTest [message #1791899 is a reply to message #1791898] Fri, 06 July 2018 11:46 Go to previous messageGo to next message
it is ok i tried both and it works fine
package org.xtext.example.mydsl3.tests
import org.eclipse.xtext.testing.AbstractLanguageServerTest
import org.junit.Assert
import org.junit.Test
class MyTest extends AbstractLanguageServerTest {
	new() {
		super("mydsl3")
	@Test
	def void test02_openFile() throws Exception {
		initialize();
		val file = 'hello.mydsl3'.writeFile("")
		file.open('''
			Hello Xtext!
		Assert.assertTrue("There're issues in file 'hello.mydsl'.", diagnostics.get(file).empty)
Re: Problems using AbstractLanguageServerTest [message #1791900 is a reply to message #1791899] Fri, 06 July 2018 11:49 Go to previous messageGo to next message
How does your build.gradle file look like?
Re: Problems using AbstractLanguageServerTest [message #1791901 is a reply to message #1791900] Fri, 06 July 2018 11:52 Go to previous messageGo to next message
no change besides the workaround for signature exception.
=> i am sure you have the wrong file extension
Re: Problems using AbstractLanguageServerTest [message #1791902 is a reply to message #1791901] Fri, 06 July 2018 11:55 Go to previous messageGo to next message
I also have this test and this does not work either:
@Test
	def void testEndCompletion() {
		testCompletion[
			model = '''Hello Xtext'''
			line = 0
			column = 10
			expectedCompletionItems = '''!'''
Re: Problems using AbstractLanguageServerTest [message #1791903 is a reply to message #1791901] Fri, 06 July 2018 11:56 Go to previous messageGo to next message
can you please share your complete hello world project
Re: Problems using AbstractLanguageServerTest [message #1791905 is a reply to message #1791903] Fri, 06 July 2018 11:59 Go to previous messageGo to next message
I packed everything as ZIP archive and removed the .gradle folder.
Re: Problems using AbstractLanguageServerTest [message #1791906 is a reply to message #1791905] Fri, 06 July 2018 12:12 Go to previous message
you use junit 5 .
abstractlanguageservertest does not support that.
please open a bug at xtext-core
workaround:
class AbstractScreenServiceLSPTest extends AbstractLanguageServerTest {
	new() {
		super('screenservice')
	@Before @BeforeEach
	override void setup() {
		super.setup()
Previous Topic:Inheritance from non-grammar java class
Next Topic:Formatting Scientific Notation
Current Time: Sun Jul 20 12:31:13 EDT 2025
Powered by FUDForum. Page generated in 0.05459 seconds
