Home » Eclipse Projects » NatTable » Use of coma in formula
Use of coma in formula [message #1791803] Thu, 05 July 2018 09:22 Go to next message
Hi everyone,
I am using NatTable formula feature and I would like to know what is the use of "," in formula.
For example, when I write the formula : "=A1,A2" NatTable display "A1,A2" but when I put "=A1, A2" (with a white space after the coma) NatTable display the reference value of the A2 cell.
Pauline
Re: Use of coma in formula [message #1791810 is a reply to message #1791803] Thu, 05 July 2018 10:00 Go to previous messageGo to next message
Actually I don't understand your formula. What do you expect that should happen on A1,A2? I suppose the formula parser sees the whole thing as a text without the space and with the space it can only interprete A2 because A1, is not understandable.
Re: Use of coma in formula [message #1791838 is a reply to message #1791810] Fri, 06 July 2018 01:24 Go to previous messageGo to next message
Please note that Excel reports both variants you showed as a formula error!
Re: Use of coma in formula [message #1791852 is a reply to message #1791838] Fri, 06 July 2018 04:41 Go to previous messageGo to next message
Thank you Dirk for your quick answer,
I am sorry, my question was not clear. I was not sure if the comma was interpreted and had a meaning, I was not understanding the result of my tests. Now I understand, but I think that it is strange that there is a result when the formula is not entirely interpreted, I think that it could get back a formula error or could be interpreted it as a string.
Pauline
Re: Use of coma in formula [message #1791856 is a reply to message #1791852] Fri, 06 July 2018 04:54 Go to previous message
Feel free to create a ticket
Previous Topic:Problem using SortColumnCommand on a table with a CompositeFreezeLayer
Next Topic:How to select rows with matching text in whole row or single column
Current Time: Sun Jul 20 16:28:53 EDT 2025
Powered by FUDForum. Page generated in 0.03645 seconds
