Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Forms custom file extension/file type
EMF Forms custom file extension/file type [message #1787194] Mon, 21 May 2018 16:16 Go to next message
No Message Body
[Updated on: Thu, 31 December 2020 14:47] by Moderator
Re: EMF Forms custom file extension/file type [message #1787518 is a reply to message #1787194] Mon, 28 May 2018 03:19 Go to previous messageGo to next message
what exactly do you mean by "open" the file with EMF Forms? Do you use the EMF Forms editor?
Jonas
Re: EMF Forms custom file extension/file type [message #1787533 is a reply to message #1787518] Mon, 28 May 2018 05:20 Go to previous messageGo to next message
Sorry for the terminology mixup. I don't mean opening .view files.
I mean after I have created a set of custom views and I am testing my my view models, I am running into an issue with both import and export of XMI files that do not have the .xmi file extension.
I would like to be able to import and export .xmi files with the same file extension as the rest of the team is using. Right now I am only presented with the .xmi option for importing projects or importing children.
So, for example if the Sirius team gives me a file that is called "oursample.system" I currently have to rename it to "oursample.xmi" to be able to import it into an EMF Forms based application.
Re: EMF Forms custom file extension/file type [message #1787565 is a reply to message #1787533] Tue, 29 May 2018 04:38 Go to previous messageGo to next message
Sorry for another question:
What exactly is a "EMF Forms based application"? Do you use the EMF Client Platform Model Explorer? Or more precisly: where exactly do you trigger the import/export ?
Jonas
Re: EMF Forms custom file extension/file type [message #1791658 is a reply to message #1787565] Tue, 03 July 2018 07:26 Go to previous messageGo to next message
I am trying to use the sample e3 application to test layouts created with EMF Forms, but I am using models created by Sirius modelling tools.
When I use the EMF store provider, I can only import .xmi files, but if I use "Eclipse Workspace Experimental" i can import any file I want.
Why is this, and can I modify this behavior?
Also, is there better documentation available than is available on the website? Much of that is nonsensical or missing material.
Re: EMF Forms custom file extension/file type [message #1791685 is a reply to message #1791658] Wed, 04 July 2018 03:27 Go to previous messageGo to next message
if you work with Sirius, maybe you use a custom version of an Eclipse Modeling edition, rather than the e3 example application. This would include the default Project Explorer, where you directly import files into the workspace.
You could then create an editor embedding EMF Forms or use the generic editor: https://eclipsesource.com/blogs/tutorials/emf-forms-editors/
I hope this help, but it is very difficult to suggest the right way to go without knowing the detailed requirements about your project.
About the documentation: Feedback is highly appreciated, please point our missing material or "nonsensical" parts, so that those can be fixed.
Jonas
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: EMF Forms custom file extension/file type [message #1791792 is a reply to message #1791685] Thu, 05 July 2018 07:31 Go to previous messageGo to next message
Re: Documentation,
An example of documentation that makes no sense or is incomplete is the "view proxy" example.
https://eclipsesource.com/blogs/tutorials/emf-forms-view-model-elements/
The example code is blank and there are NO working examples to be found on the web.
Another example is the "control grid" example.
How does one implement a control grid, following these instructions? There seems to be nothing like this to be found while working with EMF forms.
Re: EMF Forms custom file extension/file type [message #1791864 is a reply to message #1791792] Fri, 06 July 2018 06:15 Go to previous messageGo to next message
Thank you for the report, we have refined both sections
Jonas
Re: EMF Forms custom file extension/file type [message #1791865 is a reply to message #1791864] Fri, 06 July 2018 06:23 Go to previous message
Jonas,
Beautiful, thank you!
I have also recently found a dead link:
The page:
leads to the dead page:
https://eclipsesource.com/blogs/emf-forms-custom-control-areas/
Thank you again!
Previous Topic:Pb change version ECP
Next Topic:[Emf Forms] Tooltips in Views
Current Time: Sun Jul 20 09:48:57 EDT 2025
Powered by FUDForum. Page generated in 0.05428 seconds
