Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Pb change version ECP(org.eclipse.emf.ecp.ui.view.ECPRendererException: No EMFFormsRendererService available! at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:95))
Pb change version ECP [message #1791647] Tue, 03 July 2018 06:04 Go to next message
Hi all,
I have updated ECP with version 1.17 and now I have the following problem:
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:95).
My code is this one:
    if (selectedNode != null && !(selectedNode instanceof Group)) {
      try {
        if ((scrolledComponent != null) && (!scrolledComponent.isDisposed())) {
          scrolledComponent.dispose();
        scrolledComponent =
            new ScrolledComposite(myParent, SWT.H_SCROLL | SWT.V_SCROLL | SWT.BORDER);
        content = new Composite(scrolledComponent, SWT.NONE);
        content.setBackground(myParent.getDisplay().getSystemColor(SWT.COLOR_WHITE));
        content.setLayout(GridLayoutFactory.fillDefaults().margins(10, 10).create());
        content.setLayoutData(GridDataFactory.fillDefaults().create());
        if (ProjectImpl.getCurrentProject() != null) {
          for (Control kid : content.getChildren()) {
            kid.dispose();
          try {
            VView view = ViewProviderHelper.getView(selectedNode, null);
            DefaultReferenceService service = new DefaultReferenceService();
            final ViewModelContext vmc = ViewModelContextFactory.INSTANCE
                .createViewModelContext(view, selectedNode, service);
            ECPSWTViewRenderer.INSTANCE.render(content, vmc);
            content.layout();
          } catch (final /* ECPRenderer */Exception e) {
             e.printStackTrace();
          content.getParent().layout();
          content.setSize(content.computeSize(SWT.DEFAULT, SWT.DEFAULT));
          scrolledComponent.setContent(content);
          scrolledComponent.getParent().layout();
      } catch (Exception e) {
Can you help me?
Re: Pb change version ECP [message #1791694 is a reply to message #1791647] Wed, 04 July 2018 05:18 Go to previous messageGo to next message
Hi Antonio,
from which version are you upgrading?
Do you have errors when validating your run config?
Eugen
Re: Pb change version ECP [message #1791699 is a reply to message #1791694] Wed, 04 July 2018 06:30 Go to previous messageGo to next message
Hi was before on version 1.16 and in the run configuration I validate the plugins and all is OK
Here you will found all the pugins I use
Re: Pb change version ECP [message #1791700 is a reply to message #1791699] Wed, 04 July 2018 06:54 Go to previous messageGo to next message
hmm.
You could try to add the "org.eclipse.emfforms.setup.base" and check which bundles are missing using the "Validate Plug-ins" button.
You can ignore *.indexdmr and *.mappingdmr bundles if you have them in your run config.
I hope this helps.
Eugen
Re: Pb change version ECP [message #1791705 is a reply to message #1791700] Wed, 04 July 2018 08:27 Go to previous messageGo to next message
If i add this plugin ("org.eclipse.emfforms.setup.base") I am oblige to add (see attachement) but also I cannot anymore ignore *.indexdmr and *.mappingdmr bundles.
This doesn't solve the problem still the same error!!!
Re: Pb change version ECP [message #1791718 is a reply to message #1791705] Wed, 04 July 2018 09:04 Go to previous messageGo to next message
Are you using Photon by any chance?
Eugen
Re: Pb change version ECP [message #1791722 is a reply to message #1791718] Wed, 04 July 2018 09:20 Go to previous messageGo to next message
Hi Eugen,
Yes I use Photon is for this reason that I use 1.17, is this the reason? If yes, I understand.
Cheers
Antonio
Re: Pb change version ECP [message #1791730 is a reply to message #1791722] Wed, 04 July 2018 10:04 Go to previous messageGo to next message
Photon is the reason. We debugged the same error as you have today.
Photon changed the order in which bundles are started.
Equinox.ds is setting a property which tells Apache Felix SCR to keep services even if they are no longer used by anybody. Before Photon Equinox ds was started with "start level" 1 and "auto start" true. With Photon this is no longer the case and Apache Felix SCR is started instead.
With this config the parameter Equinox.ds was setting is no longer available and the service is disposed. This uncovers a bug in ecp.
So we know of 2 solutions:
1. fix the start order by setting apache.felix.scr auto-start to false and start level to 1
2. manually pass in a system property: "ds.delayed.keepInstances" with the value "true"
Eugen
Re: Pb change version ECP [message #1791740 is a reply to message #1791730] Wed, 04 July 2018 11:25 Go to previous messageGo to next message
HI Eugen
Thanks a lot for your help. When do you expect fix "this bug", to remove the workaround?
Cheers
Antonio
Re: Pb change version ECP [message #1791758 is a reply to message #1791740] Wed, 04 July 2018 17:53 Go to previous messageGo to next message
Hi Antonio,
I think we will only manage to do it with the 1.18 release which will be part of Photon.1 in September.
Eugen
Re: Pb change version ECP [message #1791759 is a reply to message #1791758] Wed, 04 July 2018 17:53 Go to previous message
Btw here is the issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=536692
Previous Topic:[EMFForms] Get label + control from view model elements as SWT control?
Next Topic:EMF Forms custom file extension/file type
Current Time: Sun Jul 20 18:41:02 EDT 2025
Powered by FUDForum. Page generated in 0.26316 seconds
