Home » Modeling » TMF (Xtext) » Ecore.genmodel: Feature not found? (Oxygen -> Photon migration (Xtext 2.12.0 --> 2.14.0))
Ecore.genmodel: Feature not found? [message #1791423] Fri, 29 June 2018 04:07 Go to next message
I ported my RCP application "ASSIST" from Oxygen to Photon yesterday. You can find it here [1]. Of course, I had to change my pom.xml to make use of the newer Xtext version. I changed my properties to:
<properties>
        <assist.version>2.5.0-SNAPSHOT</assist.version>
        <tycho.version>1.2.0</tycho.version>
        <xtextVersion>2.14.0</xtextVersion>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
        <maven.compiler.source>1.8</maven.compiler.source>
        <maven.compiler.target>1.8</maven.compiler.target>
        <emf-version>2.12.0</emf-version>						<!-- Photon: 2.14.0   	-->
        <emf-common-version>2.12.0</emf-common-version>				<!-- Photon: 2.14.0   	-->
        <emf-codegen-version>2.12.0</emf-codegen-version>			<!-- Photon: 2.14.0   	-->
        <ecore-xtext-version>1.2.0</ecore-xtext-version>			<!-- Photon: 1.3.0    	-->
        <ecore-xcore-version>1.3.1</ecore-xcore-version>			<!-- Photon: 1.6.0    	-->
        <ecore-xcore-lib-version>1.1.100</ecore-xcore-lib-version> 	              <!-- Photon: 1.2.0 		-->
   </properties>
(see pom.xml )
I am unable to set the values to the versions of the plugins that are part of Photon, because Eclipse complains, that the dependencies are missing (not in maven central yet?).
However, the build goes through (see [2]), but it complains about missing features in the genmodel of Ecore. I suppose, that this is a result of the fact, that the EMF versions are a bit old for Xtext 2.14.0?
3147 ERROR XtextGeneratorLanguage - Error loading 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel':
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'eclipsePlatformVersion' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'autoResizeProperties' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'autoExpandProperties' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'findAction' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'expandAllAction' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'collapseAllAction' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'revertAction' not found. (platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel, 9, 91)
Any tips or pointers? Are there any other maven repositories with more recent versions of EMF/Ecore?
Robert
[1]: https://github.com/RobertHilbrich/assist-public
[2]: https://travis-ci.org/RobertHilbrich/assist-public/jobs/398116651#L4030
Re: Ecore.genmodel: Feature not found? [message #1791424 is a reply to message #1791423] Fri, 29 June 2018 04:10 Go to previous message
https://github.com/eclipse/xtext/issues/1233
Previous Topic:Error with optional semicon at the end of line
Next Topic:Is Maven supposed to work properly?
Current Time: Sun Jul 20 02:42:59 EDT 2025
Powered by FUDForum. Page generated in 0.03256 seconds
