Home » Archived » Eclipse SmartHome » ESH Google IoT core binding
ESH Google IoT core binding [message #1790941] |
Wed, 20 June 2018 08:19  |
I have created one java class for publishing the event message in cloud IoT core through ESH binding, if I try to run that java class by stand alone java class in Eclipse IDE it is executed but when I try to execute that java class through binding it is not executed.
Note: we created new binding using below command
./create_openhab_binding_skeleton.sh
I followed the instructions from https://github.com/GoogleCloudPlatform/java-docs-samples link.
I have created the device in google cloud through below code
mvn exec:java \
-Dexec.mainClass="com.example.cloud.iot.examples.MqttExample" \
-Dexec.args="-project_id=brss-711 \
-registry_id=reg1 \
-cloud_region=asia-east1 \
-device_id=java-device-1 \
-private_key_file=../rsa_private_pkcs8 \
-message_type=state \
-algorithm=RS256"
then I am publishing the event message through the below code
mvn exec:java \
-registry_id=reg1 \
-algorithm=RS256"
I want to integrate these two program through Eclipse Smarthome Binding to create device at google IoT core and publish ESH event message.
Please help me to resolve this issue.
Re: ESH Google IoT core binding [message #1790992 is a reply to message #1790942] |
Thu, 21 June 2018 02:40   |
Hi Henning thanks for the reply,
Here the java class that i have implemented
public class MqttExample {
// [START iot_mqtt_jwt]
/** Create a Cloud IoT Core JWT for the given project id, signed with the given RSA key. */
private static String createJwtRsa(String projectId, String privateKeyFile) throws Exception {
DateTime now = new DateTime();
// Create a JWT to authenticate this device. The device will be disconnected after the token
// expires, and will have to reconnect with a new token. The audience field should always be set
// to the GCP project id.
JwtBuilder jwtBuilder =
Jwts.builder()
.setIssuedAt(now.toDate())
.setExpiration(now.plusMinutes(20).toDate())
.setAudience(projectId);
byte[] keyBytes = Files.readAllBytes(Paths.get(privateKeyFile));
PKCS8EncodedKeySpec spec = new PKCS8EncodedKeySpec(keyBytes);
KeyFactory kf = KeyFactory.getInstance("RSA");
return jwtBuilder.signWith(SignatureAlgorithm.RS256, kf.generatePrivate(spec)).compact();
/** Create a Cloud IoT Core JWT for the given project id, signed with the given ES key. */
private static String createJwtEs(String projectId, String privateKeyFile) throws Exception {
Jwts.builder()
KeyFactory kf = KeyFactory.getInstance("EC");
return jwtBuilder.signWith(SignatureAlgorithm.ES256, kf.generatePrivate(spec)).compact();
// [END iot_mqtt_jwt]
// [START iot_mqtt_configcallback]
static MqttCallback mCallback;
/** Attaches the callback used when configuration changes occur. */
public static void attachCallback(MqttClient client, String deviceId) throws MqttException {
mCallback = new MqttCallback() {
public void connectionLost(Throwable cause) {
// Do nothing...
public void messageArrived(String topic, MqttMessage message) throws Exception {
String payload = new String(message.getPayload());
System.out.println("Payload : " + payload);
// TODO: Insert your parsing / handling of the configuration message here.
public void deliveryComplete(IMqttDeliveryToken token) {
// Do nothing;
String configTopic = String.format("/devices/%s/config", deviceId);
client.subscribe(configTopic, 1);
client.setCallback(mCallback);
// [END iot_mqtt_configcallback]
/** Parse arguments, configure MQTT, and publish messages. */
public static void main(String[] args) throws Exception {
// [START iot_mqtt_configuremqtt]
MqttExampleOptions options = MqttExampleOptions.fromFlags(args);
if (options == null) {
// Could not parse.
System.exit(1);
// Build the connection string for Google's Cloud IoT Core MQTT server. Only SSL
// connections are accepted. For server authentication, the JVM's root certificates
// are used.
final String mqttServerAddress =
String.format("ssl://%s:%s", options.mqttBridgeHostname, options.mqttBridgePort);
// Create our MQTT client. The mqttClientId is a unique string that identifies this device. For
// Google Cloud IoT Core, it must be in the format below.
final String mqttClientId =
String.format(
"projects/%s/locations/%s/registries/%s/devices/%s",
options.projectId, options.cloudRegion, options.registryId, options.deviceId);
MqttConnectOptions connectOptions = new MqttConnectOptions();
// Note that the Google Cloud IoT Core only supports MQTT 3.1.1, and Paho requires that we
// explictly set this. If you don't set MQTT version, the server will immediately close its
// connection to your device.
connectOptions.setMqttVersion(MqttConnectOptions.MQTT_VERSION_3_1_1);
Properties sslProps = new Properties();
sslProps.setProperty("com.ibm.ssl.protocol", "TLSv1.2");
connectOptions.setSSLProperties(sslProps);
// With Google Cloud IoT Core, the username field is ignored, however it must be set for the
// Paho client library to send the password field. The password field is used to transmit a JWT
// to authorize the device.
connectOptions.setUserName("unused");
DateTime iat = new DateTime();
if (options.algorithm.equals("RS256")) {
connectOptions.setPassword(
createJwtRsa(options.projectId, options.privateKeyFile).toCharArray());
} else if (options.algorithm.equals("ES256")) {
createJwtEs(options.projectId, options.privateKeyFile).toCharArray());
} else {
throw new IllegalArgumentException(
"Invalid algorithm " + options.algorithm + ". Should be one of 'RS256' or 'ES256'.");
// [END iot_mqtt_configuremqtt]
// [START iot_mqtt_publish]
// Create a client, and connect to the Google MQTT bridge.
MqttClient client = new MqttClient(mqttServerAddress, mqttClientId, new MemoryPersistence());
// Both connect and publish operations may fail. If they do, allow retries but with an
// exponential backoff time period.
long initialConnectIntervalMillis = 500L;
long maxConnectIntervalMillis = 6000L;
long maxConnectRetryTimeElapsedMillis = 900000L;
float intervalMultiplier = 1.5f;
long retryIntervalMs = initialConnectIntervalMillis;
long totalRetryTimeMs = 0;
while (!client.isConnected() && totalRetryTimeMs < maxConnectRetryTimeElapsedMillis) {
try {
client.connect(connectOptions);
} catch (MqttException e) {
int reason = e.getReasonCode();
// If the connection is lost or if the server cannot be connected, allow retries, but with
// exponential backoff.
System.out.println("An error occurred: " + e.getMessage());
if (reason == MqttException.REASON_CODE_CONNECTION_LOST
|| reason == MqttException.REASON_CODE_SERVER_CONNECT_ERROR) {
System.out.println("Retrying in " + retryIntervalMs / 1000.0 + " seconds.");
Thread.sleep(retryIntervalMs);
totalRetryTimeMs += retryIntervalMs;
retryIntervalMs *= intervalMultiplier;
if (retryIntervalMs > maxConnectIntervalMillis) {
retryIntervalMs = maxConnectIntervalMillis;
} else {
throw e;
attachCallback(client, options.deviceId);
// Publish to the events or state topic based on the flag.
String subTopic = options.messageType.equals("event") ? "events" : options.messageType;
// The MQTT topic that this device will publish telemetry data to. The MQTT topic name is
// required to be in the format below. Note that this is not the same as the device registry's
// Cloud Pub/Sub topic.
String mqttTopic = String.format("/devices/%s/%s", options.deviceId, subTopic);
// Publish numMessages messages to the MQTT bridge, at a rate of 1 per second.
for (int i = 1; i <= options.numMessages; ++i) {
String payload = String.format("%s/%s-payload-%d %s", options.registryId, options.deviceId, i,"hi");
System.out.format(
"Publishing %s message %d/%d: '%s'\n",
options.messageType, i, options.numMessages, payload);
// Refresh the connection credentials before the JWT expires.
// [START iot_mqtt_jwt_refresh]
long secsSinceRefresh = ((new DateTime()).getMillis() - iat.getMillis()) / 1000;
if (secsSinceRefresh > (options.tokenExpMins * 60)) {
System.out.format("\tRefreshing token after: %d seconds\n", secsSinceRefresh);
} else {
client.disconnect();
client.connect();
// [END iot_mqtt_jwt_refresh]
// Publish "payload" to the MQTT topic. qos=1 means at least once delivery. Cloud IoT Core
// also supports qos=0 for at most once delivery.
String a="hi";
MqttMessage message = new MqttMessage(payload.getBytes());
message.setQos(1);
client.publish(mqttTopic, message);
if (options.messageType.equals("event")) {
// Send telemetry events every second
Thread.sleep(5000);
} else {
// Note: Update Device state less frequently than with telemetry events
Thread.sleep(5000);
// Disconnect the client if still connected, and finish the run.
if (client.isConnected()) {
System.out.println("Finished loop successfully. Goodbye!");
// [END iot_mqtt_publish]
following attachment consists of binding structure.
Note:If I run MqttExample.java alone in java application I am able publish the event message.
This java class embedded in a binding to the ESH framework is successfully run by "standalone" but I am not able to run this java class through binding.
please help me to resolve this issue.
Current Time: Sat Jul 19 12:53:51 EDT 2025
Powered by FUDForum. Page generated in 0.28662 seconds
