Home » Modeling » TMF (Xtext) » Create files only once
Create files only once [message #1791127] Sun, 24 June 2018 09:14 Go to next message
Create files only once.
Hi guys.
I would like to create some files in a project only the first time. But if a skip the generation the second time on, xtext has been deleting the files created previously. I think it makes sence, but how I can solve this issue and keep these files?
Márcio Koch.
Re: Create files only once [message #1791128 is a reply to message #1791127] Sun, 24 June 2018 09:16 Go to previous messageGo to next message
How did you configure the outlet? Inside the outputconfiguration there should be an option for that
Re: Create files only once [message #1791135 is a reply to message #1791128] Sun, 24 June 2018 17:38 Go to previous messageGo to next message
It is not working for me, when I save my DSL file, the generated files which should be kept (OUTPUT_KEEPED configuration), are removed if exists and created otherwise.
class MklOutputConfigurationProvider extends OutputConfigurationProvider {
	public static val DEFAULT_OUTPUT_DIRECTORY = "."
	public static val APP_OUTPUT_DIRECTORY = DEFAULT_OUTPUT_DIRECTORY + "/modules/app/"
	public static val OUTPUT_KEEPED = "OUTPUT_KEEPED"
	override getOutputConfigurations() {
		val defaultOutput = new OutputConfiguration(IFileSystemAccess.DEFAULT_OUTPUT)
		defaultOutput.description = "Default and base output."
		defaultOutput.outputDirectory = DEFAULT_OUTPUT_DIRECTORY
		defaultOutput.createOutputDirectory = true
		val outputConfigKeepResources = new OutputConfiguration(OUTPUT_KEEPED)
		outputConfigKeepResources.description = "Keep generated files"
		outputConfigKeepResources.outputDirectory = APP_OUTPUT_DIRECTORY
		outputConfigKeepResources.createOutputDirectory = true
		outputConfigKeepResources.overrideExistingResources = false
		outputConfigKeepResources.setDerivedProperty = false
		outputConfigKeepResources.canClearOutputDirectory = false
		outputConfigKeepResources.cleanUpDerivedResources = false
		newHashSet(defaultOutput, outputConfigKeepResources)
Debugging, Eclipse falls in this code that always associates the files with the DSL and deletes them, they seem to be always derived files:
public boolean installMarker(IFile file, String generator, String source) throws CoreException {
		if (!file.exists())
			return false;
		IMarker[] markers = file.findMarkers(MARKER_ID, true, IResource.DEPTH_INFINITE);
		for (IMarker marker : markers) {
			if (generator.equals(marker.getAttribute(ATTR_GENERATOR))
				&& source.equals(marker.getAttribute(ATTR_SOURCE)))
				return true;
		IMarker marker = file.createMarker(MARKER_ID);
		marker.setAttribute(ATTR_GENERATOR, generator);
		marker.setAttribute(ATTR_SOURCE, source);
		return true;
I'm doing something wrong?
Re: Create files only once [message #1791138 is a reply to message #1791135] Sun, 24 June 2018 19:53 Go to previous messageGo to next message
I solved the problem by my self extending installMarker method from DerivedResourceMarkers class and checking when really is a derived file.
class MklDerivedResourceMarkers extends DerivedResourceMarkers {
	override installMarker(IFile file, String generator, String source) throws CoreException {
		val isDerived = file.isDerived()
		if (!isDerived) {
			return false
		super.installMarker(file, generator, source)
After I bind the extended class in my DSL AbstractUiModule:
@FinalFieldsConstructor
class MklUiModule extends AbstractMklUiModule {
	def Class<? extends IDerivedResourceMarkers> bindDerivedResourceMarkers() {
		return MklDerivedResourceMarkers
I don't know if this is the right way, but it works for me.
Re: Create files only once [message #1791141 is a reply to message #1791138] Mon, 25 June 2018 00:55 Go to previous message
So your files are not related to a model? Why are they generated at all then
Previous Topic:Parsing in reconciler failed. / [Model.feature] does not exist
Next Topic:Guillemets and UTF-8 encoding on Windows vs Mac
Current Time: Sun Jul 20 04:38:04 EDT 2025
Powered by FUDForum. Page generated in 0.23781 seconds
