Home » Eclipse Projects » Papyrus for Real Time » Unable to install Using the Papyrus-RT Installer(Missing requirement: artificial_root 1.0.0.v1529348522092 requires 'org.eclipse.papyrus.sdk.feature.feature.group [3.0.0,3.0.1)' but it could not be found)
Unable to install Using the Papyrus-RT Installer [message #1790835] Mon, 18 June 2018 15:05 Go to next message
Steps followed -
1. Download the file : Papyrus-RT-Installer-win64.exe
2. Run as admin and select 'Papyrus-RT'
3. choose appropriate configurations and install
Installation failed with Error -
[2018-06-18 21:01:52] Executing bootstrap tasks
[2018-06-18 21:01:52] Java(TM) SE Runtime Environment 1.8.0_171-b11
[2018-06-18 21:01:52] Product org.eclipse.papyrusrt.products.papyrus-rt.1_0
[2018-06-18 21:01:52] Bundle org.eclipse.oomph.setup 1.8.0.v20170408-0745, build=3098, branch=e12ba4db800d8f30e47fd2525429e2f55baf9396
[2018-06-18 21:01:52] Bundle org.eclipse.oomph.setup.core 1.8.0.v20170531-0903, build=3098, branch=e12ba4db800d8f30e47fd2525429e2f55baf9396
[2018-06-18 21:01:52] Bundle org.eclipse.oomph.setup.p2 1.8.0.v20170318-0419, build=3098, branch=e12ba4db800d8f30e47fd2525429e2f55baf9396
[2018-06-18 21:01:52] Performing P2 Director (Papyrus-RT)
[2018-06-18 21:01:52] Offline = false
[2018-06-18 21:01:52] Mirrors = true
[2018-06-18 21:01:52] Resolving 18 requirements from 8 repositories to C:\papyrus-rt-1_0\Papyrus-RT
[2018-06-18 21:01:52] Requirement org.eclipse.papyrus.sdk.feature.feature.group [3.0.0,3.0.1)
[2018-06-18 21:01:52] Requirement org.eclipse.platform.ide
[2018-06-18 21:01:52] Requirement org.eclipse.platform.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.rcp.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.oomph.setup.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.codegen-feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.umlrt.cpp.feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.xtumlrt.xtext.feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.rts-feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.umlrt.migration.rsa.feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.papyrusrt.umlrt.tooling.compare.feature.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.cdt.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.egit.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.emf.compare.diagram.papyrus.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.emf.compare.egit.feature.group
[2018-06-18 21:01:52] Requirement org.eclipse.emf.compare.rcp.ui.feature.group
[2018-06-18 21:01:52] Repository http://download.eclipse.org/papyrus-rt/updates/releases/oxygen/1.0.0/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/modeling/emf/compare/updates/logical/emf.compare/integration/3.3.1.201707041528/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/egit/updates/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/releases/oxygen/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/modeling/mdt/papyrus/components/designer/neon/1.0.4_papyrus-designer-neon_494/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/modeling/mdt/papyrus/interoperability/rsa/updates/oxygen/1.4.0/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/oomph/updates/release/latest/
[2018-06-18 21:01:52] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2018-06-18 21:02:02] Calculating requirements and dependencies.
[2018-06-18 21:02:03] Cannot complete the request. Generating details.
[2018-06-18 21:02:03] ERROR: org.eclipse.equinox.p2.director code=10053 Cannot complete the install because one or more required items could not be found.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.resolve(ProfileTransactionImpl.java:425)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:337)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:729)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3324)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3252)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3233)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3133)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.installPerform(SimpleVariablePage.java:1289)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.access$32(SimpleVariablePage.java:1166)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage$20.run(SimpleVariablePage.java:1111)
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1529348522092
ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: artificial_root 1.0.0.v1529348522092 requires 'org.eclipse.papyrus.sdk.feature.feature.group [3.0.0,3.0.1)' but it could not be found
Re: Unable to install Using the Papyrus-RT Installer [message #1790836 is a reply to message #1790835] Mon, 18 June 2018 15:09 Go to previous messageGo to next message
It seems that the required version of the Papyrus SDK (3.0) may have been removed from its update site or may be temporarily unavailable. You can try the installer again later. If it still fails, you'll have to install it with the RCP instead [1].
[1] https://www.eclipse.org/papyrus-rt/content/download.php#RCP
Re: Unable to install Using the Papyrus-RT Installer [message #1790871 is a reply to message #1790836] Tue, 19 June 2018 07:23 Go to previous message
Thank you.
I am currently using the RCP version for windows.
But I am getting issues similar to the ones described in discussion [1] and therefore wanted to try with the Papyrus-RT Installer (as this seemed to have resolve it)
[1] https://www.eclipse.org/forums/index.php/t/1089138/
Previous Topic:Run without code generation
Next Topic:Suspending timing services?
Current Time: Sun Jul 20 07:53:51 EDT 2025
Powered by FUDForum. Page generated in 0.03908 seconds
