Home » Modeling » UML2 » problem with IntroductionToUML2Profiles
problem with IntroductionToUML2Profiles [message #1790789] Sun, 17 June 2018 15:17 Go to next message
I have been trying to get uml2 profiles to work programmatically and downloaded uml2.articles_200607181325.zip from https://www.eclipse.org/modeling/mdt/uml2/docs/articles/Introduction_to_UML2_Profiles/article.html
I made a project and ran the code but i am getting an exception
Exception in thread "main" java.lang.IllegalArgumentException: [email][email][email][email]org.eclipse.uml2.uml.internal.impl.ClassImpl@faa3fed[/email][/email][/email][/email] (name: Property, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false) (isActive: false)
at org.eclipse.uml2.uml.internal.operations.StereotypeOperations.createExtension(StereotypeOperations.java:358)
at org.eclipse.uml2.uml.internal.impl.StereotypeImpl.createExtension(StereotypeImpl.java:270)
at org.eclipse.uml2.articles.IntroductionToUML2Profiles.createExtension(IntroductionToUML2Profiles.java:86)
at org.eclipse.uml2.articles.IntroductionToUML2Profiles.main(IntroductionToUML2Profiles.java:254)
when it calls Stereotype.createExtension
any help would be gratefully recieved
regards
gary
[Updated on: Sun, 17 June 2018 17:04] by Moderator
Re: problem with IntroductionToUML2Profiles [message #1790794 is a reply to message #1790789] Mon, 18 June 2018 01:28 Go to previous messageGo to next message
You've probably done something wrong, but without a repro there are too many things for me to guess at. You can single step the tutorial example in the debugger to see why your code fails and the example succeeds.
Ed Willink
Re: problem with IntroductionToUML2Profiles [message #1790842 is a reply to message #1790794] Mon, 18 June 2018 17:36 Go to previous messageGo to next message
Hi Ed
sorry you misunderstood me, sorry if I wasn't clear. The example code fails with the error. I haven't modified the code except for changing the package it lives in (I can revert this if you wan't but I presume it should n't make any difference).
the error occurs the first time it tries to create an extension
 createExtension(propertyMetaclass, eAttributeStereotype, false);
and calls this method
protected static Extension createExtension(
			org.eclipse.uml2.uml.Class metaclass, Stereotype stereotype,
			boolean required) {
		Extension extension = stereotype.createExtension(metaclass, required);
		out((required
			? "Required extension '"
			: "Extension '") + extension.getQualifiedName() + "' created.");
		return extension;
I can try running it on another computer and eclipse installation at work if you want.....
I can also roll up the complete eclipse project and attach [its very small]
The rest of the Getting Started with uml2 code works
its using org.eclipse.uml2.uml.resources_5.2.0.v20170227-0935.jar for resources
and the following libraries are included in the project
org.eclipse.emf.ecore_2.12.0.v20160420-0247.jar
org.eclipse.emf.common_2.12.0.v20160420-0247.jar
org.eclipse.emf.ecore.xmi_2.12.0.v20160420-0247.jar
org.eclipse.uml2.common_2.1.0.v20170227-0935.jar
org.eclipse.uml2.types_2.0.0.v20170227-0935.jar
org.eclipse.emf.mapping.ecore2xml_2.9.0.v20160526-0356.jar
org.eclipse.uml2.uml.profile.standard_1.0.100.v20170227-0935.jar
other than that its a copy of the uml2.examples.gettingstarted project in eclipse Neon.3 Release (4.6.3)
regards
gary
  • Attachment: articles.tgz
    (Size: 5.09KB, Downloaded 186 times)
Re: problem with IntroductionToUML2Profiles [message #1790851 is a reply to message #1790842] Tue, 19 June 2018 01:50 Go to previous messageGo to next message
" except for changing the package" has to be the first thing to look at. The example works for me.
Ed Willink
Re: problem with IntroductionToUML2Profiles [message #1790859 is a reply to message #1790851] Tue, 19 June 2018 03:54 Go to previous messageGo to next message
I've found that the stereotype diagnostics are not helpful, so I tried to reproduce your refactoring. But failed.
The IllegalArgumentException message could be much improved, but realistically if you are skilled enough to invoke Stereotype.createExtension, you are skilled enough to read the lines immediately preceding the IAE throw. I don't feel inclined to raise a Bugzilla.
Ed Willink
Re: problem with IntroductionToUML2Profiles [message #1794537 is a reply to message #1790859] Sat, 01 September 2018 08:08 Go to previous messageGo to next message
ok so i have now had time to come back to this. The failure is at the test
!metaclass.isMetaclass() in org.eclipse.uml2.uml.internal.operations.StereotypeOperations.createExtension(StereotypeOperations.java:358) which gives false to the metaclass being a metaclass
I have looked further back in the example code and found the metaclass referred to is created as follows
	protected static org.eclipse.uml2.uml.Class referenceMetaclass(
			Profile profile, String name) {
		Model umlMetamodel = (Model) load(URI
			.createURI(UMLResource.UML_METAMODEL_URI));
		org.eclipse.uml2.uml.Class metaclass = (org.eclipse.uml2.uml.Class) umlMetamodel
			.getOwnedType(name);
		profile.createMetaclassReference(metaclass);
		out("Metaclass '" + metaclass.getQualifiedName() + "' referenced.");
		return metaclass;
which is called as follows
org.eclipse.uml2.uml.Class propertyMetaclass = referenceMetaclass(
			ecoreProfile, UMLPackage.Literals.PROPERTY.getName());
at this point I am sorry I am stumped as I don't have enough understanding of the workings of uml2 to understand what is going wrong, the code appears to be exactly the same as that in the article....
if you have a working copy of the example code could you end me yours because the one I sent to you is what I am using. Otherwise it must be a misconfiguration in my uml2/eclipse installation which is even more of a nightmare
regards
Gary
[Updated on: Sat, 01 September 2018 08:09] by Moderator
Re: problem with IntroductionToUML2Profiles [message #1794538 is a reply to message #1794537] Sat, 01 September 2018 09:16 Go to previous messageGo to next message
Your analysis no doubt means something to you since you have been struggling with it, but I doubt it means anything to anyone else.
I suggest you wrap up your problem as a JUnit test case whose failure demonstrates your concern. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=455572 for an example.
Ed Willink
Re: problem with IntroductionToUML2Profiles [message #1800646 is a reply to message #1794538] Fri, 04 January 2019 06:01 Go to previous messageGo to next message
I though I would update on where I got with this
I now have it working having followed the code in the example project org.eclipse.uml2.examples.introprofiles
this can be created by selecting new -> examples and searching for profile which brings up Introduction to UML2 profiles, this project works. Examining the downloaded zip file described above and the project there are distinct differences in the code. I haven't had the time to see what the trigger for the failure with the zip file is, but this is a solution...
regards
Gary
Re: problem with IntroductionToUML2Profiles [message #1800652 is a reply to message #1800646] Fri, 04 January 2019 08:26 Go to previous message
As Eclipse projects get older and Eclipse/project improves, old documentation can become very embarrassing.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=543170 raised.
Ed Willink
Previous Topic:[solved] getApplicableStereotypes() is empty
Next Topic:Ecore to UML
Current Time: Sun Jul 20 02:55:56 EDT 2025
Powered by FUDForum. Page generated in 0.47169 seconds
