Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » How to customize devices?(How to customize devices?)
How to customize devices? [message #1790026] Sun, 03 June 2018 10:14 Go to next message
Hi, I download 4diac-ide and create a simple project as you can see in attached file. But I can only use limited devices(I use FORTE_PC for sample project).
index.php/fa/32995/0/
How to add new different device into 4diac-ide? I have porting my rte to my own hardware, so I need add this new device into 4diac-ide, any suggestion is welcome.
Thanks a lot!
Henry
  • Attachment: device.png
    (Size: 113.55KB, Downloaded 312 times)
Re: How to customize devices? [message #1790672 is a reply to message #1790026] Thu, 14 June 2018 04:27 Go to previous message
You don't need to add your new device if you don't have any new variable to add to it (lie MGR_ID). Even your ported RTE should work if no changes in the interface of the device was done. But if you really want to add a new one, I'd say you could look for the file FORTE_PC.dev in the t ypelibrary of your 4diac project, and copy and edit it. It's a plain XML file
Previous Topic:Enabling Exceptions
Next Topic:Export FB networks, FB interfaces and ECCs as PDF or SVG
Current Time: Sat Jul 19 23:37:30 EDT 2025
Powered by FUDForum. Page generated in 0.03602 seconds
