[Edapt] Feature not found when migrating [message #1790345] |
Fri, 08 June 2018 09:00  |
Hi all!
I am still struggling with the integration of Edapt into my project.
I have 2 models, a base model and an extension that references the base model. I created a history only for the extension model. The base model resource is added to the extension model ecore file. The initial history release contains the full set of operations to create the base+extension model.
Now, as a change to the model, I changed a class name in the extension model, regenerated the genmodel, the model and edit code.
My editor detects the old model version when I load an old model instance from a file resource. But the migration process throws an exception like:
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'type' not found.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.emf.edapt.internal.common.ResourceUtils.loadResourceSet(ResourceUtils.java:133)
at org.eclipse.emf.edapt.internal.migration.internal.Persistency.loadModel(Persistency.java:110)
at org.eclipse.emf.edapt.internal.migration.execution.internal.MigrationReconstructor.loadRepository(MigrationReconstructor.java:189)
at org.eclipse.emf.edapt.internal.migration.execution.internal.MigrationReconstructor.endRelease(MigrationReconstructor.java:159)
at org.eclipse.emf.edapt.history.reconstruction.CompositeReconstructorBase.endRelease(CompositeReconstructorBase.java:179)
at org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:81)
at org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:57)
at org.eclipse.emf.edapt.history.reconstruction.CompositeReconstructorBase.reconstruct(CompositeReconstructorBase.java:74)
at org.eclipse.emf.edapt.migration.execution.Migrator.migrate(Migrator.java:269)
at org.eclipse.emf.edapt.migration.execution.Migrator.migrateAndLoad(Migrator.java:221)
... 107 more
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'type' not found.
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeature(XMLHandler.java:2027)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1991)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2743)
at org.eclipse.emf.ecore.xmi.impl.SAXXMLHandler.handleObjectAttribs(SAXXMLHandler.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2229)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1366)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1504)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(XMLDTDValidator.java:745)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1359)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(XMLDocumentScannerImpl.java:1289)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3132)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:852)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:842)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:771)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 118 more
Obviously, when migrating the old model instance the migrator is not able to find model features from the (base) model.
The extension_model.history is registered as migrator to the org.eclipse.emf.edapt.migrators extension point. All plugin dependencies are added.
Do I miss something? Can anyone help, please?
Gernot.
Re: [Edapt] Feature not found when migrating [message #1790752 is a reply to message #1790678] |
Fri, 15 June 2018 11:03   |
Hi!
Thanks for looking into the code. With the proposed changes I was able to get the example running.
However, on my real case code it still does not work. I went done with the debugger and found that the method call resourceSet.getResource(modelURI, true) fails. This is called in ResourceUtils.loadResourceSet(...):
Both, migrateAndLoad() and migrateAndSave() are ending up at this method and, thus, both fail. So migrateAndXXX() throws an exception that the package with the nsURI from the previous model (version 1.0) was not found.
Usually, in my code I use the createResource() method to return the resource:
final ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(modelURI);
The modelURI is exactly the same in both cases. When I try createResource() directly in my code the resource is returned without any exception. Interestingly, in ResourceUtils.loadResourceSet(...) the createResource() method was commented out. Any reasons for this?
Honestly, I am not sure what the difference between createResource() and getResource() actually is. The context help for getResource() says that: "...the package registry is used to resolve the namespace URI...". Can this be the root cause because the previous model package is not registered?
Thanks and regards,
Gernot.
FUDForum. Page generated in 0.03923 seconds
