Home » Eclipse Projects » JFace » Where to get Jface source code including compile information
Where to get Jface source code including compile information [message #1787168] Mon, 21 May 2018 04:03 Go to next message
I want to optimize some codes in Jface and compile it for test. I can get the source code by "Import As" -> "Source Project" in Plug-ins perspective. I can not find any source repository of Jface.
Where can i get the source code with compile information, such as pom file.
Re: Where to get Jface source code including compile information [message #1787175 is a reply to message #1787168] Mon, 21 May 2018 06:03 Go to previous messageGo to next message
The Chart title and legend are displayed on the top at the center. Using the position property of title, I can either put it on left, top, right, bottom.
I would like to display it on top-left corner instead of top-center. Is it possible?
Thanks in Advance
Re: Where to get Jface source code including compile information [message #1787198 is a reply to message #1787168] Mon, 21 May 2018 22:24 Go to previous messageGo to next message
http://git.eclipse.org/c/platform/eclipse.platform.ui.git/tree/bundles/org.eclipse.jface
The JFace bundle has an `Eclipse-SourceReference` header. If you have EGit in your installation, this should be sufficient for Eclipse to automatically hook up to the corresponding source repository.
Eclipse-SourceReferences: scm:git:git://git.eclipse.org/gitroot/platform/eclipse.platform.ui.git;path="bundles/org.eclipse.jface";tag="I20180423-0640";commitId=4ffb3577eb39eb9558dd9427fb7c7b4ddbdf87dc
Re: Where to get Jface source code including compile information [message #1787270 is a reply to message #1787198] Tue, 22 May 2018 23:02 Go to previous messageGo to next message
Hi, Brian de Alwis
Thanks for your reply.
I want to compile the jface project, but I'm a newer for maven.
I download the eclipse.platform.ui project, and want to compile only jface or whole eclipse.platform.ui. but both get failed.
It can't find "eclipse-platform-parent", where can i get the "eclipse-platform-parent" project or something else helper for compile Jface project?
Re: Where to get Jface source code including compile information [message #1787306 is a reply to message #1787270] Wed, 23 May 2018 09:25 Go to previous messageGo to next message
You should be able to build using the `build-individual-bundles` profile. For example:
$ cd .../<git-platform-ui>/bundles/org.eclipse.jface
$ mvn -Pbuild-individual-bundles package
Hope that helps!
Re: Where to get Jface source code including compile information [message #1790000 is a reply to message #1787306] Sat, 02 June 2018 02:12 Go to previous message
Thanks you very much!
It works with build-individual-bundles.
And it need a parent pom.xml (from https://hudson.eclipse.org/platform/) and make some changes (commented out tycho-packaging-plugin related plugin section, otherwise will occur jgit error)
Previous Topic:How to get scolling in a wizard dialog
Next Topic:JFace databinding
Current Time: Sun Jul 20 05:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.08717 seconds
