Home » Modeling » TMF (Xtext) » The trick doesn't work for a rule that may be consumed without object instantiation
The trick doesn't work for a rule that may be consumed without object instantiation [message #1787156] Sun, 20 May 2018 06:39 Go to next message
So I came across what seems to be a common issue as searching yields lots of questions on it, the message:
The rule 'BlockType' may be consumed without object instantiation. Add an action to ensure object creation, e.g. '{BlockType}'.
Basically, all answers just say "add {rulename}" and the reply is "oh thanks, it works" but in my case it doesn't. See self-contained grammar for my case.
grammar org.thisAndThat.dsl.SbeDsl with org.eclipse.xtext.common.Terminals
generate thatThatDsl "http://www.thisAndThat.org/dsl/thatThatDsl"
Specification:
    As = TheAs Bs=TheBs;
TheAs:
    'theAs' '{' (theAs+=A)+ '}';
TheBs:
    'theBs' '{'(theBs+=B)+ '}';
A:
    'a' name=Name;
B:
    'b' name=Name '{'
    block=BlockType
BlockType:  {BlockType}
    (thisFields+=This)* | (thatFields+=That)*;
This:
    'this' name=Name ':' type=[A];
That:
    'that' name=Name ':' type=[A];
Name:
    ID;
I would appreciate if you would explain what exactly is happening under the hood as it seems like nobody really goes into the subject... From what I gather, each rule creates an object of some (generated) type under the hood, so the fact that there are two optional (*) groups (thisFields and thatFields) means that "it may be consumed without object instantiation". Indeed, forcing "thatFields" makes the warning go away:
    (thisFields+=This)* | (thatFields+=That)+;
However, forcing "thisFields" does not have the same effect, as the below makes the warning persist:
    (thisFields+=This)+ | (thatFields+=That)*;
In reality however, I don't want my grammar to require the presence of "that": it should be possible to have only "this" or only "that" or both.
1) What is the implication of this warning if I leave BlockType as-is?
2) If I wanted to only exclude the ABSENCE of both, I would need to do that outside the grammar with custom validation, correct?
Re: The trick doesn't work for a rule that may be consumed without object instantiation [message #1787157 is a reply to message #1787156] Sun, 20 May 2018 06:45 Go to previous messageGo to next message
the easiest would be to move the '{' '}' to the BlockType.
the forced instatiation only works if there is something to be consumed at all.
Re: The trick doesn't work for a rule that may be consumed without object instantiation [message #1787158 is a reply to message #1787157] Sun, 20 May 2018 10:09 Go to previous messageGo to next message
Maybe I've misunderstood, but this still issues the warning:
B:
    'b' name=Name
    block=BlockType
   '{'  (thisFields+=This)* | (thatFields+=That)* '}';
What I've found to work is:
B:
    'b' name=Name '{'
    block=BlockType
BlockType:
   {BlockType} (thisFields+=This)* |{BlockType} (thatFields+=That)* ;
Still don't understand what's happening though...
EDIT: antlr chokes on this though, so still no joy...
[Updated on: Sun, 20 May 2018 10:20] by Moderator
Re: The trick doesn't work for a rule that may be consumed without object instantiation [message #1787159 is a reply to message #1787158] Sun, 20 May 2018 10:19 Go to previous messageGo to next message
This seems to achieve what I want (moving optionality)
    thisList =ThisList?
    thatList = ThatList?;
ThisList:
    (thisFields+=This)+
ThatList:
    (thatFields+=That)+
Re: The trick doesn't work for a rule that may be consumed without object instantiation [message #1787160 is a reply to message #1787159] Sun, 20 May 2018 11:40 Go to previous message
Precedence
'{' ((thisFields+=This)* | (thatFields+=That)*) '}';
Previous Topic:Unsuccessful build using Maven due missing EMF classes
Next Topic:Generic Map get does not return the right object?
Current Time: Sun Jul 20 13:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.03170 seconds
