BIRT Runtime [message #1784842] |
Wed, 04 April 2018 13:43  |
Hi there,
Any help really appreciated!!
I have created some reports in Eclipse Neon and they run fine in there hitting my Ingres database using the required driver.
I am trying to run from the command line and get errors, the ingres driver .jar file is in the lib folder.
I think that when the BIRTCLASSPATH is set in genreport.bat, it is too long for the environment variable and I get this
Apr 04, 2018 6:35:03 PM org.eclipse.birt.report.engine.api.ReportRunner readConfigurationFile
SEVERE: file: c:\BIRTRuntime\ReportEngine not exists!
What is the usual solution for this. Do I need to work out which of the library files I actually need to reduce the entry to the env variable? The limit is 2047? My genreport.bat file comes up with a length of over 4800 using the files in the lib folder.
Please help!!
Stephen
FUDForum. Page generated in 0.03042 seconds
