How to make nattable fill window horizontally [message #1786879] |
Mon, 14 May 2018 13:38  |
I have nattable in a composite container. I am using gridlayout in the composite container. I am setting the griddata settings on the nattable and asking to use all available by setting grabExcessHorizontalSpace.
However, when the composite resizes the nattable does not fill the composite container horizontally. How can I make the nattable resize the columns proportionally, and fill the window at all times?
When the window size is below a minimum width, then I want o enable the scroll bars.
Can someone please give me a hint on how to accomplish this..
Thanks.
Re: How to make nattable fill window horizontally [message #1786933 is a reply to message #1786929] |
Wed, 16 May 2018 01:11  |
First, you are hijacking a thread with a different topic.
Second, you refer to a dead project. The NatTable builder was closed years ago. Nobody was working on it, therefore nobody kept it up to date with the current development, so for me NatTable builder does not exist anymore. We also do not publish it, so if you use it you are doomed when it comes to automated builds on a build server. That said, I recommend to not rely on the builder and I also will reject any contribution to that project. Actually I now think about even removing it from the repository. But probably not before 1.6.
Becoming a contributor is easy, create an Eclipse account and an account for Gerrit, create a ticket, push your changes to Gerrit for a review and wait for review comments and at the end the changes will be merged by me. We should have a contributor guide on our website that should help.
Becoming a committer means to provide good contributions for a while to prove that you know what you are doing and that you are familiar with our project rules.
FUDForum. Page generated in 0.04333 seconds
