Problem with remote debugging [message #775067] |
Thu, 05 January 2012 03:56  |
I want to debug a C application on embedded linux using RSE. I have created a new connection in RSE Perspective and there I can browse the files (download and upload with drag and drop), run a console or a shell without problems.
Then I created a new debug configuration where I specified the remote connection, path to store the files and debugger options. Unfortunately when I try to run the debug session I'm getting following error
2012-01-05 09:52:30.639 | Worker-16 | SftpFileService.upload rse
2012-01-05 09:52:30.643 | Worker-16 | Sftp-monitor: 2320221, capture_dmai
Sftp-monitor <--
2012-01-05 09:52:33.504 | Worker-16 | SftpFileService.upload rse ok
2012-01-05 09:52:33.508 | Worker-16 | SftpFileService.upload /root/rse failed: org.eclipse.rse.services.files.RemoteFileIOException: Operation failed. File system input or output error
The file is uploaded (I can see it on the remote target) but no gdbserver or a command to execute before application (chmod +x) is executed there. I have tried also to upload the file manually and skip the download, but the situation is the same, none is executed on remote system.
Could please anyone give me some hint how to solve this problem?
I'm using Eclipse Indigo with TM 3.3 on Ubuntu 11.10.
best regards
Jan
[Updated on: Thu, 05 January 2012 03:57] by Moderator
Re: Problem with remote debugging [message #1786687 is a reply to message #1786617] |
Wed, 09 May 2018 08:48  |
If i remember it correctly, my main issue was that I do not realized, that I need to fill absolute filepath in remote debug configuration. So eg. /root/mynewapp.
When I use this remote debug on embedded boards based on buildroot eclipse displays some error about missing locale but when you run it again it will work...
FUDForum. Page generated in 0.25603 seconds
