Home » Modeling » TMF (Xtext) » need enum with some value
need enum with some value [message #1786232] Fri, 27 April 2018 06:52 Go to next message
I'm just begining with Xtext.
I want a rule in which if I provide :
" dataType unit8" in my file
I want a grammar in which will give a dropdown to choose unit8 and internally unit8 will have some path eg : /abc/xyz/
may be in grammar the enum should look like :
basicDataType : unit8='/abc/xyz/';
so when i generate a xml file from my text file it should have "/abc/xyz/unit8"
Re: need enum with some value [message #1786238 is a reply to message #1786232] Fri, 27 April 2018 09:33 Go to previous messageGo to next message
What do you mean by „generate a xml file „
Re: need enum with some value [message #1786362 is a reply to message #1786238] Wed, 02 May 2018 02:06 Go to previous messageGo to next message
its just a file which is generated from my text
Re: need enum with some value [message #1786368 is a reply to message #1786362] Wed, 02 May 2018 03:48 Go to previous message
but then i dont understand your question. you can hardcode in your generator whatever you like
Previous Topic:How can i override XTextBuilder ??
Next Topic:Debugging DSL based on Xbase
Current Time: Sat Jul 19 23:24:21 EDT 2025
Powered by FUDForum. Page generated in 0.03910 seconds
