How to change lexer to copy tokens from other files [message #1785730] |
Thu, 19 April 2018 01:58  |
I am giving example below and I will explain my problem scenarios.
Grammar:
grammar com.hpe.nsdee.lexer.LexerDsl with org.eclipse.xtext.common.Terminals hidden ( COPY_STMT, WS )
generate lexerDsl "http://www.hpe.com/nsdee/lexer/LexerDsl"
Model:
greetings+=Greeting*;
Greeting:
'Hello' name=ID '!';
terminal COPY_STMT : 'Copy' -> ';';
Model files(test1.lex):
Hello virag!
Copy c:\temp\test2.lex;
Purnam!
Hello newName!
test2.lex contents which is outside workspace:
Parser throws error at "Purnam!".
What I want to achieve is at "Copy c:\temp\test2.lex;", DslLexer should return tokens from test2.lex file. Actual contents if DslLexer does that.
Hello virag!
Hello anotherName!
Hello
Purnam!
Hello newName!
In this case parser will not give any error.
How can I achieve this?
I tried changing in DslLexer directly for hard coded values.
I returned Token Hello with correct token state type when I get Copy statement. It worked.
But I want it to dynamic and this is example grammar.
Actual grammar will have more combinations.
Thanks in advance.
Thanks and regards,
Virag Purnam
[Updated on: Thu, 19 April 2018 02:00] by Moderator
Re: How to change lexer to copy tokens from other files [message #1786557 is a reply to message #1785795] |
Mon, 07 May 2018 04:26  |
I have added below code in runtime module.
public Class<? extends org.eclipse.xtext.parser.IParser> bindIParser() {
return RetokenizingParser.class;
public static class RetokenizingParser extends LexerDslParser
protected XtextTokenStream createTokenStream(TokenSource tokenSource) {
return super.createTokenStream(new CustomTokenStream(tokenSource, getTokenDefProvider().getTokenDefMap()));
CustomTokenStream class:
package com.hpe.nsdee.lexer;
import java.io.BufferedReader;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.Reader;
import java.net.MalformedURLException;
import java.net.URI;
import java.net.URL;
import java.nio.charset.Charset;
import java.util.ArrayList;
import java.util.LinkedList;
import java.util.List;
import java.util.Map;
import org.antlr.runtime.ANTLRReaderStream;
import org.antlr.runtime.CommonToken;
import org.antlr.runtime.Token;
import org.antlr.runtime.TokenSource;
import org.eclipse.xtext.parser.IParseResult;
import org.eclipse.xtext.parser.antlr.Lexer;
import org.eclipse.xtext.parser.antlr.LexerBindings;
import org.eclipse.xtext.parser.antlr.XtextTokenStream;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.ui.editor.model.XtextDocumentProvider;
import com.google.inject.Inject;
import com.google.inject.Provider;
import com.google.inject.name.Named;
public class CustomTokenStream implements TokenSource {
protected final TokenSource tokenSource;
protected final Map<Integer, String> tokenDefMap;
protected final LinkedList<Token> queue = new LinkedList<Token>();
public static Integer value = 0;
public static List<String> words = new ArrayList<>();
public static Integer lineNumber = 0;
public static Integer charPositionInLine = 0;
public static Integer start = 0;
public static Integer stop = 0;
@Inject
@Named(LexerBindings.RUNTIME)
private Provider<Lexer> lexerProvider;
public CustomTokenStream(TokenSource tokenSource, Map<Integer, String> tokenDefMap) {
this.tokenSource = tokenSource;
this.tokenDefMap = tokenDefMap;
this.words = new ArrayList<>();
lineNumber = 0;
start = 0;
stop = 0;
public String getSourceName() {
return tokenSource.getSourceName();
public Token nextToken() {
while (words.size() > 0) {
String word = words.get(0);
CommonToken commonToken = getToken(word);
words.remove(words.get(0));
System.out.println(commonToken.toString());
return commonToken;
Token nextToken = tokenSource.nextToken();
if (nextToken.getText() != null && !nextToken.getText().isEmpty() && nextToken.getText().startsWith("Copy")) {
List<String> wordsFromFile = readFileAndReturnWords("c:\\temp\\test1.lex");
words.addAll(wordsFromFile);
lineNumber = nextToken.getLine();
start = ((CommonToken) nextToken).getStartIndex();
stop = ((CommonToken) nextToken).getStopIndex();
charPositionInLine = nextToken.getCharPositionInLine();
return commonToken;
if(nextToken.getText() == null) {
return Token.EOF_TOKEN;
System.out.println(nextToken.toString());
return nextToken;
private CommonToken getToken(String word) {
CommonToken commonToken = null;
switch (word) {
case "Hello":
commonToken = new CommonToken(12, "Hello");
break;
case "!":
commonToken = new CommonToken(13, "!");
break;
case "\r\n":
commonToken = new CommonToken(10, " ");
break;
default:
commonToken = new CommonToken(4, word);
break;
commonToken.setLine(lineNumber);
// charPositionInLine = charPositionInLine + commonToken.getText().length();
commonToken.setCharPositionInLine(0);
// commonToken.setStartIndex(start+1);
// start = start + commonToken.getText().length();
// commonToken.setStopIndex(start);
return commonToken;
private List<String> readFileAndReturnWords(String filePath) {
try (InputStream fis = new FileInputStream(filePath);
InputStreamReader isr = new InputStreamReader(fis, Charset.forName("UTF-8"));
BufferedReader br = new BufferedReader(isr);) {
String line;
while ((line = br.readLine()) != null) {
String[] wordArray = line.split(" ");
for (String word : wordArray) {
if (!word.trim().isEmpty()) {
words.add(word);
words.add("\r\n");
return words;
} catch (Exception e) {
// TODO: handle exception
return new ArrayList<>();
model files:
Hello Aneesh!
Copy C:\\temp\\test1.lex;
Hello arun!
Hello Anitha!
Hello Senthil!
test1.lex
Hello name1 !
Hello name2 !
Hello name3 !
Hello name4 !
Hello name5 !
Hello name6 !
Correct output:
Hello Aneesh!
Hello name1 !
Hello name2 !
Hello name3 !
Hello name4 !
Hello name5 !
Hello name6 !
Hello arun!
Hello Anitha!
Hello Senthil!
But after this dsl editor lines and positions goes wrong on edit.
On edit, changes are reflecting at wrong place.
I need help here.
How can I update editor with proper line numbers and how to modify text region?
Thanks and regards,
Virag Purnam
FUDForum. Page generated in 0.24017 seconds
