Home » Newcomers » Newcomers » Installing of eclipse is crashing (WIN10)
Installing of eclipse is crashing (WIN10) [message #1785500] Sun, 15 April 2018 17:35 Go to next message
Dear community,
i'd really appreciate your help.. Everytime I'm trying to run the eclipse installer there ist this Message seaking me ...
Could anyone help me with this please..?
!SESSION 2018-04-15 23:06:38.469 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_161
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64 -data @noDefault
!ENTRY org.eclipse.oomph.setup.installer 4 0 2018-04-15 23:06:43.039
!MESSAGE 0
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.oomph.setup.internal.installer.SimpleProductPage.aboutToShow(SimpleProductPage.java:227)
at org.eclipse.oomph.setup.internal.installer.SimpleInstallerDialog.doSwitch(SimpleInstallerDialog.java:660)
at org.eclipse.oomph.setup.internal.installer.SimpleInstallerDialog.switchToPage(SimpleInstallerDialog.java:672)
at org.eclipse.oomph.setup.internal.installer.SimpleInstallerDialog.createUI(SimpleInstallerDialog.java:247)
at org.eclipse.oomph.setup.internal.installer.AbstractSimpleDialog.show(AbstractSimpleDialog.java:139)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.run(InstallerApplication.java:250)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:408)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!ENTRY org.eclipse.osgi 4 0 2018-04-15 23:06:43.080
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:354)
at org.eclipse.swt.widgets.Shell.getShells(Shell.java:1160)
at org.eclipse.jface.window.Window.getModalChild(Window.java:603)
at org.eclipse.jface.window.Window.lambda$0(Window.java:164)
at org.eclipse.jface.window.Window.getParentShell(Window.java:632)
at org.eclipse.jface.dialogs.IconAndMessageDialog.getSWTImage(IconAndMessageDialog.java:277)
at org.eclipse.jface.dialogs.IconAndMessageDialog.getErrorImage(IconAndMessageDialog.java:236)
at org.eclipse.jface.dialogs.MessageDialog.init(MessageDialog.java:245)
at org.eclipse.jface.dialogs.MessageDialog.<init>(MessageDialog.java:182)
at org.eclipse.oomph.ui.ErrorDialog.<init>(ErrorDialog.java:47)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication$6.<init>(InstallerApplication.java:415)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:415)
Re: Installing of eclipse is crashing (WIN10) [message #1785531 is a reply to message #1785500] Mon, 16 April 2018 07:12 Go to previous message
Which installer did you download? The code from the stack frames looks kind of old. You can download a newer installer from here:
https://wiki.eclipse.org/Eclipse_Installer
Then if you still have a problem, at least I can at least match the line numbers to my code.
Previous Topic:adt plugin issue
Next Topic:Slow Eclipse
Current Time: Sun Jul 20 08:43:10 EDT 2025
Powered by FUDForum. Page generated in 0.08981 seconds
