Home » Archived » BIRT » Max File Size pdf(Technical Question )
Max File Size pdf [message #1785491] Sun, 15 April 2018 10:06 Go to next message
Hi.
Is there a max file size that the BIRT engine can produce?
i need to create a very large archive report in pdf format.
Re: Max File Size pdf [message #1785631 is a reply to message #1785491] Tue, 17 April 2018 11:32 Go to previous messageGo to next message
Not sure, but If there is, I've never hit it. But if you're referring to width, I believe it's around 200 inches.
Re: Max File Size pdf [message #1785882 is a reply to message #1785631] Sun, 22 April 2018 05:41 Go to previous messageGo to next message
Thanks.
i need to send it later on so i'm interested in the file size in MB\GB
Re: Max File Size pdf [message #1792957 is a reply to message #1785882] Thu, 26 July 2018 09:41 Go to previous messageGo to next message
As far as I know, the maximum file size ever possible is up to 10 GB. There's no relevant info on what part of it BIRT could handle yet I guess it's ten times smaller. And even so, I barely can imagine what such a pdf could contain. I think even the report of size close to 500 mb would cause a freeze, you ought to get it compressed with the tool like this https://ds11.pdffiller.com yet it's an online so I can't claim it won't freeze because of that thing as well
Re: Max File Size pdf [message #1835242 is a reply to message #1792957] Fri, 27 November 2020 15:11 Go to previous messageGo to next message
I've never thought about such question before. I'll try to figure out, how it's possible to solve it
Re: Max File Size pdf [message #1835600 is a reply to message #1835242] Tue, 08 December 2020 04:23 Go to previous message
After looking through different websites I haven't found such kind of restrictions. It seems not to be true.  At least I've never had such problem before. You can appeal to their help service and ask them. The maximum size may be around 9-10GB. It's big enough to contain all necessary information/ I don't think it's possible to hit it or to overcome. I've been using for my work this service  https://pdfliner.com/ds_11_form. It's suitable for using online. And yes, here you can't make a file of a very big size, but it's more suitable for work rather than other sources (as for me)
Previous Topic:Merging Similar Data of multiple rows and showing as one
Next Topic:blank excel
Current Time: Sat Jul 19 09:32:03 EDT 2025
Powered by FUDForum. Page generated in 0.07395 seconds
