Home » Eclipse Projects » e(fx)clipse » How to Generate Template to create Custom E(fx)clipse Project?
How to Generate Template to create Custom E(fx)clipse Project? [message #1785455] Fri, 13 April 2018 23:11 Go to next message
I would like to know how to generate a template to generate my own e(fx)clipse project structure. Pretty much in the same way that ones select New->New Project->e4 Application Projects (or OSGi Bundle Project).
@Tom could you tell me which technologies you used to generate the initial project context from (I presume) a template and where I can see the code?
Thanks!
Re: How to Generate Template to create Custom E(fx)clipse Project? [message #1785481 is a reply to message #1785455] Sat, 14 April 2018 19:53 Go to previous message
If anyone else is interested, I forgot to mention that I saw the following Post from Tom and it is very interesting:
https://tomsondev.bestsolution.at/2012/12/10/automated-eclipse-project-creation-and-deployment-for-javafx/
Also, browsing the sources I found the module
org.eclipse.fx.ide.pde.ui.e4_3.2.0.201803260700
is the one containing the generator tasks, but it has many warnings with discouraged access (the type XXX is not API).
[Updated on: Sat, 14 April 2018 20:05] by Moderator
Previous Topic:Problem resolving @PostConstruct and @PreDestroy
Next Topic:Export e4 Media Application
Current Time: Sun Jul 20 15:53:58 EDT 2025
Powered by FUDForum. Page generated in 0.03179 seconds
