Home » Newcomers » Newcomers » adt plugin issue(android project opening with errors.)
adt plugin issue [message #1785321] Thu, 12 April 2018 08:41 Go to next message
Hi my android project opens with errors any time i create a project don't know how to solve the issue. Secondly i cant install jboss and wildfly servers. Gives me an Unhandled loop event exception. Any ideas pls its urgent. Wasn't developing on eclipse previously.
Hi I am attaching screenshots of my Project Window, the Main Activity, And all my android build tools from my sdk manager. I am also showing a screen shot to show that the eclipse installation isn't generating any log files. They are all attached.index.php/fa/32591/0/
index.php/fa/32592/0/
index.php/fa/32593/0/
index.php/fa/32594/0/index.php/fa/32595/0/
Below is also an image of parts of the code
index.php/fa/32601/0/
Adding two snippets of the log file.
Find them attached
[Updated on: Thu, 12 April 2018 23:34] by Moderator
Re: adt plugin issue [message #1785325 is a reply to message #1785321] Thu, 12 April 2018 09:36 Go to previous messageGo to next message
"Opens with errors" isn't much to go on.
What errors? Are the errors new? (i.e. did this work before?) What, specifically, do you have installed to support Android development?
Regarding the exception... more information is needed. What, specifically, does the error message say? Can you post the relevant parts of the log (look in [workspace]/.metadata/.log)
Re: adt plugin issue [message #1785328 is a reply to message #1785325] Thu, 12 April 2018 10:30 Go to previous messageGo to next message
Pls i have edited my question addressing your questions, pls look it up
Re: adt plugin issue [message #1785361 is a reply to message #1785328] Thu, 12 April 2018 22:32 Go to previous messageGo to next message
Pls i added on more screenshot of the code for the mainactivity class showing most of the errors. Pls view it.
Re: adt plugin issue [message #1785362 is a reply to message #1785361] Thu, 12 April 2018 22:46 Go to previous messageGo to next message
The file with no name is likely the log file (Windows is probably hiding the ".log" extension). What's in there?
Re: adt plugin issue [message #1785363 is a reply to message #1785362] Thu, 12 April 2018 23:34 Go to previous messageGo to next message
Added two attachments of parts of the log
[Updated on: Fri, 13 April 2018 00:24] by Moderator
Re: adt plugin issue [message #1785421 is a reply to message #1785363] Fri, 13 April 2018 11:32 Go to previous messageGo to next message
Neither of the posted log entries have anything to do with the "Unhandled loop event exception". Is there a log entry that has those words in its header?
Regarding the Android app, there's not enough information for me to help. I have no experience with importing Android apps. My best guess is that the resource compiler isn't engaging. Have you installed/connected an Android SDK?
Re: adt plugin issue [message #1785422 is a reply to message #1785421] Fri, 13 April 2018 11:35 Go to previous message
yeah android SDK is installed. sorted out the unhandled loop issue though
Previous Topic:Debugger speedups using cython not found
Next Topic:Installing of eclipse is crashing (WIN10)
Current Time: Sun Jul 20 18:43:07 EDT 2025
Powered by FUDForum. Page generated in 0.11201 seconds
