Home » Modeling » TMF (Xtext) » Integration with Xbase - Domain model example
Integration with Xbase - Domain model example [message #1784961] Fri, 06 April 2018 06:37 Go to next message
I'm trying to play with the DomainModel example shipped with Xtext 2.12 and investigating how the inferrer works. However, the sample model given https://www.eclipse.org/Xtext/documentation/104_jvmdomainmodel.html does not work. Here are the error messages I'm getting:
Couldn't resolve reference to JvmIdentifiableElement '+'. test.dmodel
Couldn't resolve reference to JvmIdentifiableElement 'sortBy'.
Just to be complete, here is the sample (copied from Xtext documentation)
import java.util.List
entity Person {
    firstName: String
    friends: List<Person>
    address : Address
    op getFullName() : String {
        return firstName + " " + name;
    op getFriendsSortedByFullName() : List<Person> {
        return friends.sortBy[ f | f.fullName ]
entity Address {
    street: String
    zip: String
    city: String
and the grammar (also cross-checked with the template project and the Xtext web dec)
grammar org.eclipse.xtext.example.domainmodel.Domainmodel with
                                      org.eclipse.xtext.xbase.Xbase
generate domainmodel "http://www.xtext.org/example/Domainmodel"
Domainmodel:
    importSection=XImportSection?
    elements+=AbstractElement*;
AbstractElement:
    PackageDeclaration | Entity;
PackageDeclaration:
    'package' name=QualifiedName '{'
Entity:
    'entity' name=ValidID ('extends' superType=JvmTypeReference)? '{'
        features+=Feature*
Feature:
    Property | Operation;
Property:
    name=ValidID ':' type=JvmTypeReference;
Operation:
    'op' name=ValidID
        '('(params+=FullJvmFormalParameter
        (',' params+=FullJvmFormalParameter)*)?')'
    body=XBlockExpression;
Any idea?
Fabian
Re: Integration with Xbase - Domain model example [message #1784971 is a reply to message #1784961] Fri, 06 April 2018 07:35 Go to previous messageGo to next message
Add Xbase Lib to the classpath of your project
Re: Integration with Xbase - Domain model example [message #1785023 is a reply to message #1784971] Sat, 07 April 2018 19:33 Go to previous messageGo to next message
That perfectly makes sense... Newbie mistake. Thanks!
[Updated on: Sat, 07 April 2018 19:34] by Moderator
Re: Integration with Xbase - Domain model example [message #1785210 is a reply to message #1785023] Tue, 10 April 2018 20:16 Go to previous messageGo to next message
I have the same problem. Having double checked the inclusion of Xbase lib in classpath, I still have the mentioned problem. In fact, I cannot use any binary operator, neither any built-in function call such as println(). Would you please elaborate more on this problem and the probable causes for that?
@Fabian: I am wondering if you could fix your problem. If yes, could you explain what exactly you did.
Best,
Mohammad
Re: Integration with Xbase - Domain model example [message #1785269 is a reply to message #1785210] Wed, 11 April 2018 15:31 Go to previous messageGo to next message
Can you post a screenshot of your runtime eclipse showing the dependency added
Re: Integration with Xbase - Domain model example [message #1785276 is a reply to message #1785210] Wed, 11 April 2018 17:41 Go to previous messageGo to next message
I did it the "old-fashioned" way (simple Java project, no maven/gradle) by downloading the jar from Maven and adding the jar in my classpath (Configure Build Path > Librairies > Add Jars/external jars).
index.php/fa/32586/0/
Re: Integration with Xbase - Domain model example [message #1785282 is a reply to message #1785276] Thu, 12 April 2018 00:38 Go to previous messageGo to next message
org.eclipse.xbase.lib has additional dependencies (e.g. Guava) that are missing here. Use Add Library on this page, Xtext ships a library container for convenience.
Re: Integration with Xbase - Domain model example [message #1785283 is a reply to message #1785282] Thu, 12 April 2018 01:05 Go to previous message
can you post a screenshot of the complete eclipse with project explorer and file open?
and did you check you inferrer twice?
[Updated on: Thu, 12 April 2018 01:06] by Moderator
Previous Topic:Issue with a keyword interfering in another rule
Next Topic:Embed Editor
Current Time: Sun Jul 20 07:54:34 EDT 2025
Powered by FUDForum. Page generated in 0.72030 seconds
