Home » Modeling » TMF (Xtext) » Open remote file (on server) in Xtext DSL editor is read only(Open remote file (on server) in Xtext DSL editor is read only)
Open remote file (on server) in Xtext DSL editor is read only [message #1785146] Tue, 10 April 2018 01:12 Go to next message
I am trying to open a remote file (file is on server).
The file opens in dsl editor, grammar and outline works fine.
But the file is read only. I am not able to edit the file.
I need help in this topic. How to make file editable?
Thanks in advance.
Virag Purnam
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785147 is a reply to message #1785146] Tue, 10 April 2018 01:17 Go to previous messageGo to next message
What do you mean by open
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785148 is a reply to message #1785147] Tue, 10 April 2018 01:27 Go to previous messageGo to next message
Hello Mr. Christian Dietrich,
I have a new wizard named as Open Remote File.
This wizard has browse option to select file from remote server.
On click of Open button in wizard, file content gets displayed in editor. (Read only)
I want to update contents of file and save them directly in remote server.
I hope, I am clear to explain you the problem.
Virag Purnam
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785149 is a reply to message #1785148] Tue, 10 April 2018 01:34 Go to previous messageGo to next message
That does no answer my question. What does this open do.
Does editing work in other editors. Did you debug why it's not editable,e
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785151 is a reply to message #1785149] Tue, 10 April 2018 01:41 Go to previous messageGo to next message
URI uri = OssFileSystem.getUriFor(hostUserNamePair, remotePath);
fileStore = EFS.getStore(uri);
and OssFileSystem extends org.eclipse.core.filesystem.provider.FileSystem
We are using the above code for it.
[Updated on: Tue, 10 April 2018 01:43] by Moderator
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785153 is a reply to message #1785151] Tue, 10 April 2018 02:14 Go to previous messageGo to next message
then you should debug why the editor considers this a readonly.
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785160 is a reply to message #1785153] Tue, 10 April 2018 03:36 Go to previous messageGo to next message
What is your remote access protocol? http: and https: are often readonly. Have you checked that other tools, e.g. Notepad, are able to edit and save the edited file?
Ed Willink
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785161 is a reply to message #1785146] Tue, 10 April 2018 03:37 Go to previous messageGo to next message
Is there a read-only flag set? Open the file's properties from context menu.
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785166 is a reply to message #1785160] Tue, 10 April 2018 04:27 Go to previous messageGo to next message
Same approach works, if we open C file or any text file.
But the behaviour is not same with dsl files.
We are using SFTP file transfer protocol.
Thanks and regards,
Virag Purnam
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785167 is a reply to message #1785161] Tue, 10 April 2018 04:29 Go to previous messageGo to next message
I am not able see the file properties through context menu.
Thanks and regards,
Virag Purnam
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785169 is a reply to message #1785167] Tue, 10 April 2018 05:01 Go to previous messageGo to next message
as i said: please use the debugger e.g. at org.eclipse.ui.texteditor.AbstractTextEditor.isEditorInputReadOnly()
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785183 is a reply to message #1785169] Tue, 10 April 2018 07:01 Go to previous messageGo to next message
Thanks Mr. Christian Dietrich,
I debugged the code suggested by you and found place which is responsible for making that read only.
Currently I just returned hard coded values and it worked.
I need to add proper code in below methods.
	public boolean isModifiable(Object element) {
		return true;
	public boolean isReadOnly(Object element) {
		return false;
Thanks a lot.. :)
Re: Open remote file (on server) in Xtext DSL editor is read only [message #1785184 is a reply to message #1785169] Tue, 10 April 2018 07:01 Go to previous message
		return true;
		return false;
Thanks a lot.. :)
Previous Topic:Grammar help
Next Topic:Initialization of default values on parsing
Current Time: Sun Jul 20 02:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.06680 seconds
