Home » Eclipse Projects » Eclipse Platform » Show marker in the editor without reopen.
Show marker in the editor without reopen. [message #177343] Thu, 08 January 2004 14:29 Go to next message
I use IResource.createMarker() to add a marker to the text file. But the
text editor wouldn’t show the marker in the editor area until I reopen the
file.
Anyway I can make the editor show the marker without manually reopen the
file?
Elwin
Re: Show marker in the editor without reopen. [message #177593 is a reply to message #177343] Fri, 09 January 2004 01:22 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
Elwin <elwin_ho@hp.com> wrote:
Do you use MarkerUtilities.createMarker, i.e. create markers in
IWorkspaceRunnable?
> text editor wouldn▓t show the marker in the editor area until I reopen the
> file.
> file?
> Thanks
> Elwin
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Show marker in the editor without reopen. [message #177764 is a reply to message #177593] Fri, 09 January 2004 10:48 Go to previous messageGo to next message
Originally posted by: meshcheryakovsemen.hotmail.com
As far as I remember, I had pain is the ... with the Markers also.
My final (simpliest) version works ok:
protected IMarker createMarker(
IResource resource,
String type,
Map attributes)
throws Exception
IMarker m = resource.createMarker(type);
m.setAttributes(attributes);
return m;
PS. This is not related to the temporary marks that appear
while you are editing the file.
Sam - http://openrules.com
It's better to view source code than comments to it.
Re: Show marker in the editor without reopen. [message #177969 is a reply to message #177593] Fri, 09 January 2004 21:40 Go to previous messageGo to next message
Even I change my code to use MarkerUtilities.createMarker(..), the editor
still doesn’t show the marker automatically. Any clue?
Elwin
> IWorkspaceRunnable?
> > file.
> > file?
> > Thanks
> > Elwin
Re: Show marker in the editor without reopen. [message #178079 is a reply to message #177343] Sat, 10 January 2004 13:24 Go to previous messageGo to next message
Elwin wrote:
>Hi,
>text editor wouldn?t show the marker in the editor area until I reopen the
>file.
>file?
>Thanks
>Elwin
I have noticed this problem too in 3.0M6. It seems to be a matter of
luck whether it shows in the editor or not ...
Genady Beryozkin
http://www.genady.net/
Re: Show marker in the editor without reopen. [message #178481 is a reply to message #178079] Mon, 12 January 2004 04:52 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Genady wrote:
> Elwin wrote:
>> Hi, I use IResource.createMarker() to add a marker to the text file.
>> But the
>> reopen the
>> file.
>> file?
>> Thanks
>> Elwin
You probably run into bug 49373
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=49373>
Dani
Re: Show marker in the editor without reopen. [message #178678 is a reply to message #178481] Mon, 12 January 2004 12:57 Go to previous messageGo to next message
Good news, thanks Daniel!
-- Daniel Megert
-- Fixed. Available in builds > 20040112
Daniel, Is it fixed in 2.X and 3.X?
How to find this in Bugzilla?
(Sorry for my incompetence:)
Re: Show marker in the editor without reopen. [message #179062 is a reply to message #178678] Tue, 13 January 2004 04:34 Go to previous messageGo to next message
>-- Daniel Megert
In 3.0 stream (see target milestone). The PR is not relevant for 2.x
since this has been introduced by new 3.0 code anyway.
Dani
Re: Show marker in the editor without reopen. [message #179235 is a reply to message #179062] Tue, 13 January 2004 10:27 Go to previous messageGo to next message
So, there is no such a bug in 2.X "stream" ?
Re: Show marker in the editor without reopen. [message #179310 is a reply to message #179235] Tue, 13 January 2004 12:59 Go to previous message
Check bugzilla - it has a huger memory than I do ;-)
Dani
Previous Topic:Rich Client Platform (RCP) Status
Next Topic:compare files
Current Time: Sat Jul 19 07:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.26480 seconds
